207 Pages«<121122123124125>»
catmandu
#1221 Posted : Wednesday, June 1, 2011 1:59:37 PM(UTC)
catmandu
Sounds like you are on the right track. The control board is located on the back of the refrigerator and is shown as #19 on the diagram.
- The control board Part number: AP4411082
Nice one day shipping from this site! Installed the board, we'll see what happens.
BTW, for anyone Googling on where is part number ap4411082 (also known as 2307028 from Sears), it is a little tricky: Remove back lower panel on fridge, on the left, next to compressor is a gray plastic inverter box. Remove the one screw that holds that in, then slide the gray box out . Further left is a grounding wire attached to the vertical frame. Remove that. Now look closely, you will see a single screw holding in what looks to be a plate on the interior left of the area you are working on. That actually holds a box that contains the control board (the board is held in place by white plastic retainers, which you release by squeezing with pliers).
#1222 Posted : Wednesday, June 1, 2011 3:15:46 PM(UTC)
#1223 Posted : Wednesday, June 1, 2011 3:20:58 PM(UTC)
Just wanted to thank you for sharing your repair with us. Your post was very instructive and will help other people with the same problem.
Thanks again and good luck with your refrigerator.
tandr
#1224 Posted : Thursday, June 2, 2011 8:38:14 AM(UTC)
tandr
Gene,
I have been following your troubleshooting guide as a first step process in figuring out what is wrong with my unit.
Here is a post I supplied on the open forum, please help!
Whirlpool
Full Model Number: ED22DQXEN01
There is no frost on the back panel of the freezer.
Removing the panel in the back of the freezer, the coils have a little frost on them.
I turned the defrost timer clockwise till it clicked.
There were no sizziling noise, however the coils began to defrost and drip.
I would assume the heater is working properly.
Both the freezer and fridg. temps are turned on full.
I do not get very much cool air coming from the vents n the fridge, and the temp is not very cool at all in the fridge, the freezer still maintains frozen food.
Would you need to know any more details at this point?
NOW WHAT?
Please help, Thanks,
Tim
#1225 Posted : Friday, June 3, 2011 1:39:00 PM(UTC)
Tim,
How are the evaporator coils covered with frost? If it's much less than 100% then most likely the sealed system is low on Freon.
Is the condenser clean? Does the condenser fan work?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED22DQXEN01 REFRIGERATOR | AppliancePartsPros.com
pc527
#1226 Posted : Sunday, June 5, 2011 7:42:41 PM(UTC)
pc527
I have a 4 yr old GE Monogram side-by-side refrigerator, model ZFSB25DTASS.
With the set temp at 0 for freezer / 37 for frige, the actual temp is 0/40.
I tried to set the temp to 0/35, the actual temp is then 2/37.
Do I have a faulty damper control?
There's no frost build up on the back panel in the freezer.
Thanks,
Peter
#1227 Posted : Monday, June 6, 2011 2:42:56 PM(UTC)
Originally Posted by: pc527 Go to Quoted Post
...With the set temp at 0 for freezer / 37 for frige, the actual temp is 0/40...
Peter,
How did you get these results?
Here are the breakdown diagrams and Replacement parts for General Electric ZFSB25DTASS Refrigerator | AppliancePartsPros.com
P.S. Your refrigerator does not have a damper control because it has a separate evaporator coils in the fresh food compartment.
pc527
#1228 Posted : Monday, June 6, 2011 5:05:00 PM(UTC)
pc527
Peter,
Hi Gene,
I got the results from the digital temperature display on top of frige when you open the door. I only noticed this problem after returning back on a 2 week vacation and a bunch of food in the frige grew mold, that's when i noticed the frige temp was higher than what it was set to. So i tried lowering the temp then waited 24 hours before i got the new reading.
If no damper, what do you think might be causing this problem?
Thanks,
Peter
#1229 Posted : Monday, June 6, 2011 6:12:00 PM(UTC)
Peter,
Before we'll proceed with the diagnosis I need you to measure the exact temperature in both compartments, using a refrigerator mercury thermometer.
pc527
#1230 Posted : Monday, June 6, 2011 8:36:17 PM(UTC)
pc527
Gene, where can I buy a refrigerator mercury thermometer?
I guess I'll try Bed Bath Beyond tomorrow. Digital one okay or stick with mercury?
Thanks,
Peter
Guest (10)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
