My freezer coils are frozen up and I need to locate the defrost timer.I know that you can manually turn them to see if the heater is working.I starting seeing water on the floor and the food section was not as cold as it should be.This part I'm trying to locate is not showing:confused: on your parts breakdown.Thank You
My ge refrigerator is no cooling on the refrigerator side.The freezer side was icing up.I changed the mother board.Cause the condenser fan stop working .Now the board has been changed.Model #gsh25kgrbbb
Originally Posted by: NAKIARUTH  My ge refrigerator is no cooling on the refrigerator side.The freezer side was icing up.I changed the mother board.Cause the condenser fan stop working .Now the board has been changed.Model #gsh25kgrbbb IS IT THE DEFROST TIMER?
Originally Posted by: Gene  Can you tell me where the defrost timer is located and how to adjust it ....thanks please GE gbs20kbpawn:mad: :( :confused:
Originally Posted by: charmntim  Can you tell me where the defrost timer is located and how to adjust it ....thanks please GE gbs20kbpawn:mad: :( :confused: You just quoted one of my previous posts which says "there is no defrost timer". In the other thread http://forum.appliancepartspros...erator-too-warm-183.html you mentioned that the repair guy replaced the main control board to fix it. I really don't understand why now you are looking for a defrost timer in the same refrigerator? What is wrong with the refrigerator now? Here are the breakdown diagrams and Parts for GE GBS20KBPAWW Refrigerator - AppliancePartsPros.comGene.
