ilbcnu52
#1 Posted : Friday, November 14, 2008 1:27:59 PM(UTC)
ilbcnu52
My Majic Chef electic stove Model 38fk-6txw sometimes shows an F2 error code - over temperature-too hot - even though it is not too hot. It will work OK for several days but then the F2 will appear. What is the problem? Thanks
libertyappl
#2 Posted : Friday, November 14, 2008 2:53:31 PM(UTC)
libertyappl
Sounds like the sensor is going out.
Here's the breakdown of your unit Model 38FK-6TXW.
The sensor is # 31 on the first page.
Nat
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 9/25/2015 9:01:34 AM(UTC)
Whirlpool Double Oven Error Code - Help (E6 F2 and E1 F2) (Oven Repair (including Ranges and Cooktops))
by trvsthbdx 8/24/2015 7:46:08 PM(UTC)
Double Oven Error Code interpretation (Oven Repair (including Ranges and Cooktops))
by ehenry 7/17/2014 5:20:05 AM(UTC)
Whirlpool Oven Error Code E2 F# (Oven Repair (including Ranges and Cooktops))
by ramsdellg 12/26/2013 5:39:36 AM(UTC)
GE oven error code F2 (Oven Repair (including Ranges and Cooktops))
by Tinadwalker 6/8/2013 4:26:29 PM(UTC)
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 4/18/2013 7:46:23 AM(UTC)
Whirlpool Oven Error Code F3 E2 - Replaced Oven Tem Sensor and still getting error (Oven Repair (including Ranges and Cooktops))
by loanguy7171973 11/30/2012 3:29:03 PM(UTC)
Bosch HBL745 AUC oven error code (Oven Repair (including Ranges and Cooktops))
by CWBurfle 11/3/2012 2:43:30 PM(UTC)
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 9/10/2012 10:21:53 AM(UTC)
maytag wall oven error code F5 (Oven Repair (including Ranges and Cooktops))
by net2net69 5/2/2012 9:55:22 PM(UTC)
by fred jacoby 4/4/2012 9:44:17 AM(UTC)
by sigman 3/23/2012 9:08:14 AM(UTC)
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 12/11/2011 3:37:20 PM(UTC)
by rayhol 11/16/2011 2:24:44 PM(UTC)
oven error code E-8 and broiler won't work (Oven Repair (including Ranges and Cooktops))
by norette 11/5/2011 6:15:03 PM(UTC)
