2 Pages<12
johnny1234567820
#11 Posted : Friday, November 14, 2008 12:12:48 PM(UTC)
johnny1234567820
Thanks Gene,
you probably are right. if I replace the timer and I have the same problem what would be your next best guess? I have run the timer forward manually and have engaged the wash mode with no problem, but when it comes to drain, rinse and spin, i can just hear the timer ticking along just as normal. Do you think it the contacts on all settings that is bad on the timer? or is there some solenoid that kicks in the motor to drain? and spin?
#12 Posted : Friday, November 14, 2008 12:38:30 PM(UTC)
Another possibility is a bad motor. You can use this wiring diagram to check the motor windings.
johnny1234567820
#13 Posted : Friday, November 14, 2008 1:03:29 PM(UTC)
johnny1234567820
thanks gene,
if the motor is bad why would it work fine with the wash cycle? seems to me the contacts in the timer that kicks in the pin that shoots into the pump and to activate the motor to pump and then spin. is there a transmission in this unit? is there a way to test the transmission?
#14 Posted : Friday, November 14, 2008 1:08:02 PM(UTC)
The motor is reversible and it rotates in different directions for wash and spin. It has two separate windings for that.
If the motor is silent, it has nothing to do with transmission.
johnny1234567820
#15 Posted : Friday, November 14, 2008 2:50:19 PM(UTC)
johnny1234567820
thank you gene for all your advice. one final question: what would allow the motor to work in one direction and not allow it to work in the other direction? The timer? some loose of broken wire?
Thanks for all your input, I feel ready to troubleshoot with confidence
#16 Posted : Monday, November 17, 2008 10:29:37 AM(UTC)
Originally Posted by: johnny1234567820 Go to Quoted Post
...what would allow the motor to work in one direction and not allow it to work in the other direction? The timer? some loose of broken wire?...
You are on the right track, just add the motor itself to this list.
Guest (4)
Kenmore Washer does not drain or spin (Washer Repair)
by theturtlefactory 2/27/2011 5:21:36 AM(UTC)
2 Pages<12
