sunshine2
#1 Posted : 14 years ago
sunshine2
Gas dryer won't heat up. This occured just on a normal day of washing.
Can you tell me what part and the part number is to repair?
gabe_1981
#2 Posted : 14 years ago
gabe_1981
When a gas dryer just stops heating out of the blue the first thing I check is the the ignitor ... Here is a video that shows how thats done ... Keep me informed on what you find YouTube - ‪Dryer Igniter Testing‬‏
magician59
#3 Posted : 14 years ago
magician59
Here are the components involved in the heating circuit in your dryer: The timer; thermostats; igniter; radiant sensor (also called a "flame sensor"); gas valve coils.
You need to systematically check each one of these components, so that you don't waste money on unnecessary parts purchaces.
You can eliminate some of this testing by observing the igniter. Does it glow, when you have the dryer set in a heat mode? You may be able to see the glow from under the dryer, if you can darken the room. If you do see a glowing igniter, you can surmise that the timer and thermostats are working properly.
Tell us what you find.
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 2 years ago
Gas dryer won't heat (Dryer Repair)
by pino2424 10 years ago
Kenmore Gas Dryer won't Heat (Dryer Repair)
by rboysen 11 years ago
Signature Gas Dryer Won't Heat (Dryer Repair)
by jsellnow 11 years ago
LG gas dryer won't heat up (Dryer Repair)
by Farmer85 11 years ago
Whirlpool Gas Dryer Won't Heat (Dryer Repair)
by jonellem 12 years ago
Whirlpool Duet Gas Dryer Won't Heat Up (Dryer Repair)
by evanr99 12 years ago
by Clueless2 13 years ago
by ejohnso6 13 years ago
by markdeveer@gmail.com 13 years ago
GE gas dryer won't heat (Dryer Repair)
by deadmusk 14 years ago
Brand New Gas Dryer Won't Heat (Dryer Repair)
by AMLove 14 years ago
by TimMN 14 years ago
by ikohn 14 years ago
by scolmery 14 years ago
