boomer1011
#1 Posted : Wednesday, November 12, 2008 4:03:14 PM(UTC)
boomer1011
Our oven has a light bar that seems to work fine but the gas bar does not seem to let out enough gas at times. Gas is coming through because we can smell it but will not light if I light it with a lighter a ver faint flame comes out no matter what tempature ir is set at. One day the oven will work fine and then for days will not work. Very intermittent. Also the burner lighter does not work most of the time. One day it will work and then not work for days. Thanks for your help in this matter. John
#2 Posted : Wednesday, November 12, 2008 6:42:29 PM(UTC)
Hi John,
Most likely the problem is a bad oven igniter (#16 on the break down diagram). You called this part "burner lighter".
- The part number for the oven igniter is AP3135265
- Whirlpool 465 parts for replacement parts and diagrams for all Whirlpool 465 models.
Here are the break down diagrams for the Whirlpool range Model SF325PEGW0
boomer1011
#3 Posted : Thursday, November 13, 2008 3:17:26 PM(UTC)
boomer1011
Thanks for your reply Gene,
I will give it a try and let you know.
Thanks again,
John
Guest (4)
Whirlpool Super Capacity 465 inconsistent temp (Oven Repair (including Ranges and Cooktops))
by dunleav1 6/14/2014 9:36:44 AM(UTC)
Whirlpool Super Capacity 465 Oven...intermittent heating issue (Oven Repair (including Ranges and Cooktops))
by wetzelbp 9/3/2012 4:25:33 PM(UTC)
whirlpool super capacity 465 accubake system (Oven Repair (including Ranges and Cooktops))
by jrbsafety@yahoo.com 6/11/2009 5:20:29 AM(UTC)
Whirlpool Super Capacity 465, oven won't light (Oven Repair (including Ranges and Cooktops))
by HET 4/9/2009 7:00:19 PM(UTC)
