John Whaley
#1 Posted : Thursday, October 18, 2007 9:22:14 AM(UTC)
John Whaley
Wife loaded it with a heavy load last night. Went to check when it was finished running and the clothes were still soaked. After unloading I tried to cycle the machine through. It started to spin but then shut down, waited a couple of minuets and it started to spin again and once again shut down. I can not get it to agitate. It tries to start but sounds like the motor is in a bind. The lid switch is working and the water pump is just a couple of years old. If it is the motor or transmission are they better repaired or replaced and if so is it cost effective on an older machine?
#2 Posted : Friday, October 19, 2007 2:08:37 AM(UTC)
Seems like either there is something caught in the tub or pump. I would check pump first, then shine a lit in spin basket to look for something caught in tub.
John Whaley
#3 Posted : Friday, October 19, 2007 7:21:41 AM(UTC)
John Whaley
You hit the nail on the head! I had recently replaced the pump, so I did not think of looking there. But guess what...I found a small sock caught in the pump. I was able to pull it out and now the machine works as good as new. Thanks alot, you saved me from some major expense.
miles
#4 Posted : Sunday, February 17, 2008 11:19:30 AM(UTC)
miles
how do I get my agitator apart to get to my part I need to replace?
Whirlpool Washing Machine
model LSQ9010LWO
Thank you
#5 Posted : Monday, February 18, 2008 10:55:22 AM(UTC)
Hi miles,
You can find the complete instructions in the one of my previous posts: http://forum.appliancepartspros...-auger-not-spinning.html
Here are the break down diagrams for the Whirlpool washer Model LSQ9010LW0
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
Whirlpool washing machine not spinning properly (Washer Repair)
by Guest 6/9/2021 9:12:59 PM(UTC)
Whirlpool washing machine destroying water pumps (Washer Repair)
by mjcarb 8/30/2016 11:53:49 AM(UTC)
whirlpool washing machine (Washer Repair)
by gman2233 5/27/2015 6:32:08 PM(UTC)
Whirlpool washing machine drain/spin noise (Washer Repair)
by wlakeberry84 6/24/2014 8:25:04 PM(UTC)
by tungkiu 12/5/2013 3:42:15 PM(UTC)
Whirlpool Washing Machine Plastic Washers (Washer Repair)
by ohcableman 7/4/2013 10:28:31 AM(UTC)
whirlpool washing machine will not spin out everytime (Washer Repair)
by rdgiles1 4/16/2013 6:50:00 AM(UTC)
Whirlpool Washing Machine (Washer Repair)
by Texasdiyer 3/25/2013 5:10:12 AM(UTC)
Whirlpool Washing Machine Agitates for the entire cycle (Washer Repair)
by swkucera 12/4/2012 5:09:02 AM(UTC)
by edie590 8/16/2012 8:29:21 AM(UTC)
by allantag 8/2/2012 12:58:01 PM(UTC)
by sunshine123 9/3/2011 8:05:34 PM(UTC)
