Discuss
Kenmore Series 90 Washer Auger not spinning
 in
Washer Repair
hi, I have a Kenmore Series 90 washer 8yo. Model110.20922990 The problem is that the Auger on the agitator
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 90 Washer Auger not spinning
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-24-2008, 02:18 PM
howiey@yahoo.com howiey@yahoo.com is offline
Junior Member
howiey@yahoo.com is on a distinguished road
Default Kenmore Series 90 Washer Auger not spinning
Model Number: 110.20922990   Brand: Kenmore   Age: 5 - 10 years
hi,
The problem is that the Auger on the agitator does not move all of the time. It is suppoosed to draw the clothes into the water. Sometimes it does and other times it seems to slip. I took apart down to the agiitator and everything seems to be fine. I did not see any broken or chipped parts.
Is there a part below the agitator it that is suppossed to engage the Auger and may be causing the problem?
thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-25-2008, 01:28 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem caused by the worn out agitator cam dogs (#21 on the break down diagram).
In order to remove the auger, remove the agitator cap (#1 on the break down diagram) and unscrew the retainer (#22 on the break down diagram).
You will need a 1/2" socket wrench driver to remove the retainer.
- The part number for the agitator repair kit is AP3094544
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 01-30-2008, 07:33 PM
Junior Member
Default All fixed
gene's assessment was spot on and it took less than 5 minutes to fix. I ordered the part and it was here the next day even though i used economy.
Thank you Gene!
  #4 (permalink)
Old 01-30-2008, 08:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
__________________
  #5 (permalink)
Old 05-16-2008, 10:49 AM
massager massager is offline
Junior Member
massager is on a distinguished road
Default
I know my dogs need replaced but when I go to take it apart the pin that holds the retainer sping in is just that a pin.No way to unscrew it. I have a Kenmore 90 series model #110.28922790. I do not know if there is a trick to it suck as, pull up on one part to loosen another. Any help would be greatful Thanks
  #6 (permalink)
Old 05-16-2008, 03:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I did not get what part are you talking about. Can you refer to a references number on the break down diagram?
__________________
  #7 (permalink)
Old 05-17-2008, 07:51 AM
Junior Member
Default
Gene, the part # is 21. on the diagramn. thanks
  #8 (permalink)
Old 05-19-2008, 09:49 AM
Junior Member
Default
Gene, Hi from massager I forgot to tell you the part that I need to get out is 22 on the part list. It has a pin in it , I thought thier might be a trick to get it out. Thanks
  #9 (permalink)
Old 05-20-2008, 08:29 AM
Junior Member
Default
Gene, Haven't heard from you on the washer problem. Maybe you did not get my post. The part # is 22 that I need to remove to replace part #21. Thanks massager.
  #10 (permalink)
Old 05-20-2008, 08:15 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
This is the retainer which should be unscrewed and you have to use a 1/2" socket wrench driver to do it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise Scottmcc Washer Repair 6 01-05-2008 07:24 AM
800 series kenmore with no sensors? hardhat Dryer Repair 0 12-14-2007 07:06 PM
kenmore washer 110.26852501 spinning intermittently 88ply Washer Repair 1 12-08-2007 03:01 PM
Kenmore 90 Series Wahser cid94 Washer Repair 3 11-14-2007 12:34 PM
Kenmore 80-series washer skips spin time mac Washer Repair 1 08-14-2007 06:52 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
