pwalsh
#1 Posted : Tuesday, April 26, 2011 10:49:02 AM(UTC)
pwalsh
The washer just started to make a screeching noise when its going through all the cycles except drying.Does any one have an idea where to start looking at a possible problem. Thanks
Joe / APP Team
#2 Posted : Wednesday, April 27, 2011 9:18:10 AM(UTC)
Joe / APP Team
P,
A couple of things to check,
Remove the grille cover and filter, located in the bottom of the tub, behind the spray arm tower, carefully check and reach into the sump assembly,carefully, remove any debris,and make sure theres nothing stuck in the chopper blade,
Check and make sure there is water in the tub and the unit fills properly.
You'd have a bad pump motor or impeller if that doesn't solve the noise problem.
Part number: AP2616850
Part number: AP631386
Good Luck,
pwalsh
#3 Posted : Saturday, April 30, 2011 8:38:32 AM(UTC)
pwalsh
Joe, I did what you said. I found 4 to 5 small pieces of glass and other plastic pieces of whatnot. I found the pieces against what is a screen. I try the dish washer again and the noise was gone except for once in a while and not as loud. I will check the screen again. I'll keep you posted. Thank you. Paul
Joe / APP Team
#4 Posted : Monday, May 2, 2011 6:56:14 AM(UTC)
Joe / APP Team
Paul,
Great, Nothing major, so far.
It may even clear itself, with time, but yes, check it again, be careful.
pwalsh
#5 Posted : Monday, May 2, 2011 10:07:39 AM(UTC)
pwalsh
Hello Joe, Since I last wrote, the noise is getting more frequent. How do I tell between a motor or water pump that is making the noise. Since cleaning the debris out of the screen the screeching is gone but a now its more of a grinding. What is your thoughts?
Joe / APP Team
#6 Posted : Monday, May 2, 2011 11:19:13 AM(UTC)
Joe / APP Team
Paul,
My guess,
There's still something in the assembly, most likely on the other side of the screen, in the impeller assembly,
You'll need to separate the motor from the pump housing and check for debris and damage to the impeller and associated parts.
You'll need to remove the hanger, holding the motor end up and the motor wire harness, the drain hoseand the drain solenoid linkage. loosen the 2 hose clamps holding the pump assembly to the sump. and the upper clamp attached to the spray arm assembly and carefully slide the assembly out, so you can access and remove the impeller assembly parts, and check the debris.
Good Luck,
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher Model GDT655SSJ2SS (Dishwasher Repair)
by Dan Jones 11/16/2023 11:33:43 AM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE dishwasher GDT580SSF5SS water doesn't get hot and dishes are not drying (Dishwasher Repair)
by jmbuffy 5/15/2023 4:45:57 PM(UTC)
GE Dishwasher Loads water but never agitates to clean dishes (Dishwasher Repair)
by Guest 4/19/2023 6:38:21 AM(UTC)
GE Dishwasher, Model: GDF530PGM0WW (Dishwasher Repair)
by Guest 4/12/2023 12:06:40 PM(UTC)
GE Dishwasher GSD900D-02 Door Gasket Gap (Dishwasher Repair)
by DJW000 2/5/2023 10:05:34 AM(UTC)
GE Dishwasher dead UI board (Dishwasher Repair)
by Guest 1/26/2023 9:44:03 PM(UTC)
GE dishwasher - general query about a ball at the back in the tube (Dishwasher Repair)
by delboy1881 7/27/2022 7:49:15 AM(UTC)
GE Dishwasher beeps every 10 seconds (Dishwasher Repair)
by bethH 7/12/2022 3:03:53 AM(UTC)
Ge dishwasher seal replacement (Dishwasher Repair)
by Guest 4/21/2022 5:34:16 AM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
GE dishwasher not filling and other problems (Dishwasher Repair)
by Guest 4/14/2022 3:40:35 PM(UTC)
