The baking element in my Maytag oven burned in half. I replaced the baking element, but the new element will not heat up. The display does not give me any error codes. I was told to check/replace a limiter switch so I bought one (Part #74008715). When I went to install the new switch, I can't find where it goes? Does anyone have a diagram that could help me out?
This switch is located on the back of the range (#18 on the break down diagram). This switch is resettable, just push in the red button in the center and you do not have to replace it. Gene.
