whitetail04
#1 Posted : Thursday, October 9, 2008 5:20:40 PM(UTC)
whitetail04
the clean light keeps blinking. I had a repair man about a year ago and he reset the panel. He wrote down the code but i lost it. Do you know the code to reset the panel?
v2k04
#2 Posted : Thursday, October 9, 2008 5:23:46 PM(UTC)
v2k04
you do a keypad dance i think its hi temp wash air dry hi temp wash air dry hi temp wash air dry then press start then cancel. The reaSON ITS BLINKING IS THE LAST RINSE WATER EITHER DIDN'T HEAT OR TOOK TO LONG IT COULD BE A BAD HEATER OR IT FILLED WITH COLD WATER AND DIDN'T HEAT IT ENOUGH OR(sorry caps) the board is bad hope it works
Eall
#3 Posted : Tuesday, November 4, 2008 4:16:00 PM(UTC)
Eall
Did you check behind your lower cover for instructions?
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
Kenmore standard quietguard Clean light (Dishwasher Repair)
by Signa 8/11/2020 2:23:09 PM(UTC)
whirlpool quiet partner 3 flashing clean light (Dishwasher Repair)
by tobanfrost 11/3/2018 9:04:28 AM(UTC)
blinking clean light (Dishwasher Repair)
by suzchris 8/9/2017 2:58:19 PM(UTC)
Jenn Air clean light flashes 6 then 1 (Dishwasher Repair)
by ut1031 9/1/2016 1:11:27 PM(UTC)
KitchenAid Dishwasher Clean light blinking twice, totally locked out (Dishwasher Repair)
by hermitnerd 7/13/2016 10:48:37 AM(UTC)
Clean Light Stays On (Dishwasher Repair)
by croyce 11/1/2015 10:32:00 AM(UTC)
flashing clean light no longer reset by toggle buttons (Dishwasher Repair)
by DPForumDog 8/2/2014 6:54:43 AM(UTC)
Whirlpool Clean light blinks 7 times (Dishwasher Repair)
by gmabuckeye 7/16/2014 7:17:44 AM(UTC)
Clean Light Blinks 4 Times (Dishwasher Repair)
by huds0n 12/16/2013 12:45:30 PM(UTC)
by thomazel81 5/15/2013 5:16:00 PM(UTC)
clean light is on when the door is open (Washer Repair)
by zaq007 3/4/2013 7:06:09 PM(UTC)
clean light flashing 7 times; (Dishwasher Repair)
by cfisse11 1/29/2013 1:52:26 AM(UTC)
Kenmore dishwasher *clean light* blinking - machine won't run full wash cycle (Dishwasher Repair)
by noodletoad 1/8/2013 5:12:28 PM(UTC)
Lock light and Clean light indicator does not work (Oven Repair (including Ranges and Cooktops))
by Donna J 12/14/2012 10:39:35 AM(UTC)
