huds0n
#1 Posted : Monday, December 16, 2013 12:45:30 PM(UTC)
huds0n
Our Kitchenaid dishwasher stopped working yesterday morning. The clean light blinks 4 times and pauses and then repeats. There is also a faint audio beep that beeps 15 times. Each key beeps but does not light up the LED when you press them. The exception being the control lock key. If I hold that for 3 seconds it does light up the LED. I haven't found a reset sequence that works. I have left power off for an hour but that didn't help. There is no sheet behind the kick plate to look up the code either.
Help?
Len
HumboldtRepairMan
#2 Posted : Monday, December 16, 2013 7:11:36 PM(UTC)
HumboldtRepairMan
You may have the control lock on do you see a lock picture on anything with a button sequence you can push? Usually it's a single or two buttons you press and hold for a few seconds.
Horowitz
#3 Posted : Friday, January 2, 2015 12:06:35 PM(UTC)
Horowitz
I have the same issue. The web is filled with reset suggestions but all of them have different button names than our unit. I have a "high temp scrub" button but none of the other button names mentioned for other units and brands. does anyone have any suggestions for a rest sequence for the Kitchen Aid KUDE704FXPA3
