gotkwah
#1 Posted : Tuesday, November 4, 2008 4:18:35 AM(UTC)
gotkwah
I bought this microwave a while back, and finally got around to installing it last week. Before I did, i plugged it in to check that it is working, and all the lights and display came up, the only thing i didnt check is whether it heats or not. Now that i put it up, it does not heat, at all.
Everything else works fine, except that i cannot get the nite-lite feature to turn off, so the light is always on, even though i set it to off in the options. BTW, it is not mounted over a cooktop, so it is not exposed to heat.
Model number is JVM1851BH06 manuf. in July 2006
THANKS!
v2k04
#2 Posted : Tuesday, November 4, 2008 9:16:18 AM(UTC)
v2k04
The mag still has some warranty left on it. but it could have a bad board there is a mini manual inside control panel for diagnostics and system checks.
Jessica777
#3 Posted : Wednesday, November 19, 2008 10:29:29 AM(UTC)
Jessica777
I am also having issues getting my microwave to heat. The turntable comes on as well as light. Everything seems normal, just no heat.
Model number is JVM 1340WW 002
Manufactured NOV 1996
#4 Posted : Wednesday, November 19, 2008 10:39:20 AM(UTC)
Hi Jessica,
Most likely the problem is a bad magnetron. You have to remove the microwave from the cabinet in order to access the part.
- The part number for the magnetron is AP2025937
Here are the break down diagrams for the GE microwave Model JVM1340WW02
gotkwah
#5 Posted : Sunday, November 23, 2008 12:17:46 PM(UTC)
gotkwah
Ok. I am back, with some time over the next day to try and fix this.
To answer the question that was asked: Yes, the turntable does come on.
Now, I took the MW down, but i do not have a diagram to start opening it. If anyone can point me in the right direction so i can start diagnosing it, that would be great.
Thanks!
GE Spacemaker XL1800 (Microwave Repair)
by Dsteve 11/10/2014 5:41:47 PM(UTC)
GE Spacemaker xl1800 vent fan not working (Microwave Repair)
by titannero 1/11/2013 6:27:35 AM(UTC)
GE Spacemaker XL1800 - Making Buzzing Noise (Microwave Repair)
by bunk60 7/20/2011 2:07:03 PM(UTC)
GE Spacemaker XL1800 running when you open door (Microwave Repair)
by andreah 6/30/2011 9:00:53 AM(UTC)
by Louisle16 6/28/2011 11:13:46 AM(UTC)
GE Spacemaker XL1800 won't heat (Microwave Repair)
by doanhtran@gmail.com 4/12/2011 11:31:47 AM(UTC)
by sman2626 1/11/2011 6:48:59 PM(UTC)
by guilty 11/25/2010 5:17:36 AM(UTC)
Ge spacemaker xl1800, Fan motor, light and table not working (Microwave Repair)
by mdorsey 10/22/2010 5:23:57 AM(UTC)
GE Spacemaker XL1800 hum/buzz noise but heating works (Microwave Repair)
by faraday 4/11/2009 8:08:15 PM(UTC)
GE Spacemaker XL1800 control panels locks up (Microwave Repair)
by usd777 4/6/2009 7:53:02 AM(UTC)
GE Spacemaker XL1800 will only heat when vent fan is on (Microwave Repair)
by melissams17 3/15/2009 2:34:21 PM(UTC)
GE Spacemaker XL1800 microwave making fluttering sound on startup (Microwave Repair)
by madhuvan 3/9/2009 10:23:07 PM(UTC)
GE Spacemaker XL1800 stopped heating and awful smell (Microwave Repair)
by perplexed 12/26/2007 12:20:01 PM(UTC)
