Texman1
#1 Posted : Monday, November 3, 2008 2:40:55 PM(UTC)
Texman1
I'm currently living in a rental house with a Frigidare Crown Series washingmachine, model number FWXB45RGSO. It washes and rinses fine,
but it will not or drain proceed into the spin cycle. There is a slight clicking
sound when it sounds like the spin cycle should be starting. any input would be appreciated.
jt
libertyappl
#2 Posted : Monday, November 3, 2008 2:57:11 PM(UTC)
libertyappl
If it isn't draining I would check for an obstruction in the pump. If it doesn't drain it won't spin.
Nat
kayakcrzy
#3 Posted : Tuesday, November 4, 2008 4:10:26 AM(UTC)
kayakcrzy
I do believe that you are talking about a clicking noise that is coming from the timer. If so did you try the other final spin cycles to see if it spins. If not it could be the timer, or you might want to jump out the lid switch, and then see if it will spin. Let us know what you find. Tom ApplianceEducator.com
no spin cycle on regular or permanent cycles only delicate cycle (Washer Repair)
by bhartwig 9/3/2016 5:44:07 PM(UTC)
No spin cycle on washer...need help (Washer Repair)
by 1moretoy 11/4/2014 3:57:35 PM(UTC)
Frigidaire Stackable Lid Switch Bypass no spin cycle (Washer Repair)
by billumd 9/26/2014 6:51:48 PM(UTC)
no spin cycle so clothes stay wet (Washer Repair)
by pmt1231 6/3/2014 8:23:30 PM(UTC)
Maytag Atlantis No Spin Cycle Replaced Thrust Bearing. (Washer Repair)
by MarkBe 12/21/2013 7:36:46 AM(UTC)
kenmore ~ no spin cycle (Dishwasher Repair)
by chrismo13 8/10/2013 12:42:54 PM(UTC)
No Spin Cycle (Washer Repair)
by KJH1961 1/16/2013 2:36:43 PM(UTC)
No spin cycle (Washer Repair)
by baldguywithagoat 10/8/2012 1:56:22 AM(UTC)
I replaced maytag mav6200aww brake, now no spin cycle (Washer Repair)
by jmlaudate 9/4/2012 4:28:43 PM(UTC)
Washer tumbles but no spin cycle (Washer Repair)
by jrwhitton 8/8/2012 9:13:05 AM(UTC)
Tumbles but no Spin Cycle (Washer Repair)
by Rob2001 7/23/2012 2:33:29 PM(UTC)
by John Foley 4/29/2012 11:46:11 AM(UTC)
No spin cycle or drain? Lid switch? (Washer Repair)
by 9n1Ed 4/27/2012 10:47:15 PM(UTC)
by firefly 4/27/2012 10:18:46 AM(UTC)
GE washer no spin cycle (Washer Repair)
by fsuglover 4/8/2012 4:41:33 PM(UTC)
