7 Pages«<34567>
Bohnenblust
#41 Posted : Monday, November 3, 2008 10:50:14 AM(UTC)
Bohnenblust
it seems to be calming as the inside temp goes down. how long should it take to cool to 0. also is there a temp threshold or type action in the cooling cycle, I guess I should say a hump to overcome in the cooling?
icehouse
#42 Posted : Monday, November 3, 2008 10:53:41 AM(UTC)
icehouse
:D Now you sound like my old customers, calling in as soon as I drove away complaining "Fridge is not cold". :p
Bohnenblust
#43 Posted : Monday, November 3, 2008 11:03:36 AM(UTC)
Bohnenblust
I havent had much experience with the low temp systems only cars and such.
Bohnenblust
#44 Posted : Monday, November 3, 2008 1:00:23 PM(UTC)
Bohnenblust
I am down to 8 degrees and its running 4 psi low and 175 high side. is this normal? now down to 7.5
v2k04
#45 Posted : Monday, November 3, 2008 1:25:02 PM(UTC)
v2k04
Lookin pretty good I'd say
icehouse
#46 Posted : Monday, November 3, 2008 1:50:07 PM(UTC)
icehouse
:D Good things come to those that wait. :)
Bohnenblust
#47 Posted : Monday, November 3, 2008 4:00:19 PM(UTC)
Bohnenblust
zero degrees then pulling vacuum. will let thaw overnight and see if its ice again.
arggggg
icehouse
#48 Posted : Tuesday, November 4, 2008 1:13:26 AM(UTC)
icehouse
You still have moisture in the system, however do not use thawzone as it will break down the desiccant in the drier and you will be S.O.O.L. :)
v2k04
#49 Posted : Tuesday, November 4, 2008 2:57:39 AM(UTC)
v2k04
Dump some supco oil in it That'll fix it.
Bohnenblust
#50 Posted : Tuesday, November 4, 2008 4:39:55 AM(UTC)
Bohnenblust
I let it sit all night with the door open, plugged it in this morning and its at -5.4, and the thermostat is at its lowest setting and not kicking off. I am starting to regret this project
Guest (11)
7 Pages«<34567>
