70445
#1 Posted : Sunday, November 2, 2008 3:27:07 AM(UTC)
70445
Jenn-Air model SCE70600W, control panel works for the oven but not the burners. It worked until the movers did something, anyway not working. What part do I need?
lhill@terraworld.net
kayakcrzy
#2 Posted : Sunday, November 2, 2008 5:09:17 AM(UTC)
kayakcrzy
Start looking for a harness to be unplugged, or vibrated loose. Tom ApplianceEducator.com
70445
#3 Posted : Sunday, November 2, 2008 10:02:20 AM(UTC)
70445
Where is the harness located?
kayakcrzy
#4 Posted : Sunday, November 2, 2008 1:37:36 PM(UTC)
kayakcrzy
Let me make sure I understand you, the clock works, but does the oven come on and heat up? I do understand you that the burners do not work. Also the oven worked at the last house. There could be harness in the back of the stove, that vibrated lose. But if the oven does not come on, I suspect that you do not have the proper power. Just because the clock comes on, does not mean you have proper power. Kick the breaker off, and on a few times, and see if it works. You really need to check the power at the terminal block where the oven cord, goes into the dryer. Tom ApplianceEducator.com
70445
#5 Posted : Sunday, November 2, 2008 2:53:24 PM(UTC)
70445
What you suggested worker!! Ichecked the connection to the power and reset the breaker..it works now!!! You're a genius..Thank You so very much...Larry, Pittsburg, Kansas
kayakcrzy
#6 Posted : Monday, November 3, 2008 4:05:38 AM(UTC)
kayakcrzy
Excellent. Buy the way, I live just south of you in Joplin. Pittsburg is cool little town. Tom ApplianceEducator.com
Jenn-Aire JDS-9865BPD (Oven Repair (including Ranges and Cooktops))
by Guest 1/13/2024 11:53:51 AM(UTC)
Jenn-Air JMW8527AAW display (Oven Repair (including Ranges and Cooktops))
by items 12/12/2023 1:29:40 PM(UTC)
Jenn-air JIS1450DS1 Oven Touch Control - “Start-Button" (Oven Repair (including Ranges and Cooktops))
by Guest 11/6/2023 4:31:59 PM(UTC)
Jenn-Air SVE47500B Cooling Fan Running at Low Temps (Oven Repair (including Ranges and Cooktops))
by hillridge 9/26/2023 9:04:30 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Jenn-Air Model 88370 (Oven Repair (including Ranges and Cooktops))
by Guest 6/28/2023 7:14:09 AM(UTC)
Jenn-Air 48" Built-in - JS48PPDUDB01 (Refrigerator & Freezer Repair)
by elmariachi 6/8/2023 10:54:42 AM(UTC)
Jenn-Air jfx2597aep2 refrigerator power cycling (Refrigerator & Freezer Repair)
by Jbugg 3/16/2023 7:17:18 PM(UTC)
Jenn-Air JJW9630DDB error 1d11 (Oven Repair (including Ranges and Cooktops))
by tedshred 10/2/2022 8:33:02 AM(UTC)
Jenn-Air JDS9865BDP Control Panel (Oven Repair (including Ranges and Cooktops))
by Bchip-665 1/21/2022 11:52:08 AM(UTC)
JENN-AIR MODEL JGM8130DDM SLIDE IN GAS WALL OVEN (Oven Repair (including Ranges and Cooktops))
by Guest 11/21/2021 5:35:44 PM(UTC)
Jenn-Air stove top infinite switch clicking (Oven Repair (including Ranges and Cooktops))
by JonVahsholtz 11/15/2021 9:11:15 PM(UTC)
Jenn-Air control panel wrong model installed (Oven Repair (including Ranges and Cooktops))
by Guest 11/15/2021 4:50:43 AM(UTC)
Jenn-Air Broiler (JES9800CAB01) (Oven Repair (including Ranges and Cooktops))
by BCT 11/1/2021 9:02:00 PM(UTC)
Jenn-Air spontaneous fire while turned off - JDR8895AAB/S/W (Oven Repair (including Ranges and Cooktops))
by amelanchier 11/1/2021 11:02:50 AM(UTC)
