Jenn-Air model SCE70600W, control panel works for the oven but not the burners. It worked until the movers did something, anyway not working. What part do I need? lhill@terraworld.net
Let me make sure I understand you, the clock works, but does the oven come on and heat up? I do understand you that the burners do not work. Also the oven worked at the last house. There could be harness in the back of the stove, that vibrated lose. But if the oven does not come on, I suspect that you do not have the proper power. Just because the clock comes on, does not mean you have proper power. Kick the breaker off, and on a few times, and see if it works. You really need to check the power at the terminal block where the oven cord, goes into the dryer. Tom ApplianceEducator.com
What you suggested worker!! Ichecked the connection to the power and reset the breaker..it works now!!! You're a genius..Thank You so very much...Larry, Pittsburg, Kansas lhill@terraworld.net
Excellent. Buy the way, I live just south of you in Joplin. Pittsburg is cool little town. Tom ApplianceEducator.com
