2 Pages12>
ppiotrowski@yahoo.com
#1 Posted : Wednesday, October 29, 2008 3:13:06 PM(UTC)
My washer fills with water goes through the wash cycle then stops. I bought the timer in back of the onoff button but it still is doing the same thing. I can sometimes pull the switch by hand and turn it to another cycle to go through the spin. any ideas what part i might need?
#2 Posted : Thursday, October 30, 2008 2:50:38 AM(UTC)
So the washer motor works in agitate, but then shuts off, or does it shut off at the spin period???
#3 Posted : Thursday, October 30, 2008 2:46:41 PM(UTC)
my washer shuts off before the spin cycle
#4 Posted : Friday, October 31, 2008 12:45:12 AM(UTC)
Can you get the washer to work right away after it shuts down??
#5 Posted : Friday, October 31, 2008 12:58:53 PM(UTC)
the machine stops and then i jiggle the knob to different cycles and it works sometimes and goes through the cycle.
#6 Posted : Saturday, November 1, 2008 1:13:47 AM(UTC)
Still sounds like a bad timer
#7 Posted : Saturday, November 1, 2008 8:56:17 AM(UTC)
i order a new timer switch but it does the same thing. Washes the clothes but does not go through the whole cycle. so i have to adjust the switch to another ccycle and it might go through the wash cycle as long as i adjust the knob right. what next
Jordan
#8 Posted : Sunday, November 2, 2008 3:21:42 AM(UTC)
Jordan
If timer was changed then check pressure switch, pump and how drain hose is installed.
#9 Posted : Sunday, November 2, 2008 6:02:55 AM(UTC)
which pressure switch? The pump works because if and when it runs through any cycle it does drain the water. The hose is fine.
v2k04
#10 Posted : Sunday, November 2, 2008 6:21:06 AM(UTC)
v2k04
check the lid switch it may be a coincidence from you leaning on the lid while your messing around with the timer causing pressure on the lid and making it work
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
WFW92HEFW Front Load Washer Help Needed (Washer Repair)
by Guest 5/6/2021 9:44:42 PM(UTC)
Performa Washer Help Snubber ring or Bearing? (Washer Repair)
by Keira 7/1/2019 5:59:45 AM(UTC)
Performa Washer Help (Washer Repair)
by Keira 7/1/2019 5:57:59 AM(UTC)
GE Hydrowave Washer Help (Washer Repair)
by Ae3734 1/13/2017 7:59:44 AM(UTC)
Bravos maytag washer help? (Washer Repair)
by Amwtmw 4/21/2016 8:41:03 AM(UTC)
washer help (Washer Repair)
by jackiehobson20 4/20/2014 5:59:25 PM(UTC)
Whirlpool washer help please (Washer Repair)
by jcnitram 1/16/2014 7:10:15 PM(UTC)
whirlpool ultimate care II washer help!! (Washer Repair)
by baseballmommy3 11/3/2013 1:08:54 AM(UTC)
Frigidaire Dishwasher Help (Dishwasher Repair)
by hharper1321 8/25/2013 9:23:23 AM(UTC)
Dishwasher help (Dishwasher Repair)
by redruby123 7/8/2013 7:33:06 PM(UTC)
GE Washer Help (Washer Repair)
by enigma 2/1/2013 11:47:33 AM(UTC)
Dropped washer helping unload it, could i have broken it? (Washer Repair)
by painterlynne 1/10/2013 7:53:49 PM(UTC)
Kenmore Washer Help (Washer Repair)
by nageld 9/28/2012 7:31:28 AM(UTC)
Washer Help! (Washer Repair)
by hylanderkt 8/23/2012 8:50:05 AM(UTC)
2 Pages12>
