lynfr7
#1 Posted : 14 years ago
lynfr7
Dryer stopped during a load. Breaker, outlet,and cord all checked by electrician. Have has no problems with it before, or strange noises.
#2 Posted : 14 years ago
I think the "5W0" is incorrect. The following is for a SW0
Replacement parts for WHIRLPOOL WED5700SW0 29"ELECTRIC DRYER | AppliancePartsPros.com
A common cause is a blown thermal fuse (Item 7 in Section 3).
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Next on the list would be the push-to-start relay and the door switch.
File Attachment(s):
WED5700.pdf (250kb) downloaded 4 time(s).
Kenmore Dryer stopped running (Dryer Repair)
by rd1moore 11 years ago
dryer stopped running (Dryer Repair)
by kpach 13 years ago
Roper dryer stopped running (Dryer Repair)
by tmcwilliams 13 years ago
Dryer Stopped running (Dryer Repair)
by Hawki39 14 years ago
Dryer stopped running....Please HELP!!!!! (Dryer Repair)
by JerryB. 16 years ago
by Robin Edgar 16 years ago
Electric dryer stopped running, drum light is on (Dryer Repair)
by jolybrca 17 years ago
Kenmore dryer stopped running (Dryer Repair)
by Riding 17 years ago
