brnjhn90
#1 Posted : Wednesday, December 9, 2009 2:31:56 PM(UTC)
brnjhn90
We have a 13 year old GE smooth top electric range. Last week the bake element stopped working. Everything else still works- the broil element, the burners, the clock, the timer. We bought a new bake element and it still doesn't work. If you turn the oven to bake, the bake element stays cold and the broil element cycles on and off like normal, but it takes almost an hour to reach 350 degrees. The broil function works- just the broil element. If you do the self clean feature, the broil element comes on, but the bake element doesn't. My dad came over and tested the old and new bake elements and they both work. When he opened the back of the stove and tested the connections, the broil element connection was 240 volts, but the bake element connection had nothing. On the clock/circuit board, he swapped the bake and broil wires and then the bake element would heat if the oven was turned to broil. Is replacing the clock/circuit board what we need to do or is there the possibility that something else is wrong? I don't want to spend $100+ for a new circuit board and have that not take care of the problem. My dad is hesitant about ordering the part, but he doesn't see what else it could be unless, he feels, there's a safety switch or something going on elsewhere. Any help would be appreciated.
#2 Posted : Wednesday, December 9, 2009 6:10:05 PM(UTC)
The control board is the culprit. No doubt about it.
- The control board Part number: AP2632445
brnjhn90
#3 Posted : Thursday, December 10, 2009 4:01:28 AM(UTC)
brnjhn90
Thanks for getting back to me so quickly. I'm going to order the part today and hopefully my oven will be back in business soon.
#4 Posted : Thursday, December 10, 2009 12:50:32 PM(UTC)
brnjhn90
#5 Posted : Sunday, December 13, 2009 4:58:57 AM(UTC)
brnjhn90
Just wanted to update you on my stove. The clock/control board part came yesterday. My dad came over and installed it for me and my oven is working again. I was so relieved that the part fixed the problem. Spending $100 is so much better than the expense of a new stove. I'm so happy that I won't be needing a new stove right now! Thanks again!
#6 Posted : Sunday, December 13, 2009 3:57:37 PM(UTC)
You are welcome. I'm glad you have one problem less before holidays.
Happy Holidays!
jwalter
#7 Posted : Saturday, April 16, 2011 12:00:45 PM(UTC)
jwalter
The Oven Will Not Go Past 75 Degrees. I Replaced The Igniter And The Oven (bake) Still Did Not Come On. The Broiler Works And The Self Cleaning Works. What Is Next?
jwalter
#8 Posted : Saturday, April 16, 2011 12:03:16 PM(UTC)
jwalter
MAGIC CHEF OVEN MODEL# 3468VVVA
jwalter
#9 Posted : Saturday, April 16, 2011 12:06:37 PM(UTC)
jwalter
THE OVEN STAYS AT 75 DEGREES I REPLACED THE IGNITER AND IT STILL IS AT 75 DEGREES THE BROILER IS WORKING AND SO IS THE SELF CLEANING. WHAT IS NEXT? THANK YOU
jwalter
#10 Posted : Saturday, April 16, 2011 1:34:21 PM(UTC)
jwalter
I have a Magic Chef model#3468VVV. The oven temperature does not go over 75 degrees. I replaced the igniter and I have the same problem. The broiler works and the self cleaning works. What am I to do? Thank You.
Guest (6)
Kenmore Elite Oven bake element not heating (Oven Repair (including Ranges and Cooktops))
by ADN140 12/16/2013 12:24:26 PM(UTC)
Bake Element not heating (Oven Repair (including Ranges and Cooktops))
by 1dog 6/30/2013 8:25:57 PM(UTC)
lower bake element not heating (Oven Repair (including Ranges and Cooktops))
by danasd 2/14/2013 12:17:32 PM(UTC)
Bake Element Not heating Whirlpool oven (Oven Repair (including Ranges and Cooktops))
by 3MTA3 11/2/2012 5:56:37 PM(UTC)
Bake element not heating up after replacement (Oven Repair (including Ranges and Cooktops))
by greatwhite333 5/4/2012 1:06:18 PM(UTC)
Whirlpool Oven - Lower bake element not heating (Oven Repair (including Ranges and Cooktops))
by dannyz 12/10/2010 12:58:34 PM(UTC)
by gustone 10/18/2010 11:56:44 AM(UTC)
Lower Bake Element not heating (Oven Repair (including Ranges and Cooktops))
by Shadowbyte 10/17/2010 6:18:42 AM(UTC)
Upper bake element not heating (H3 displays) (Oven Repair (including Ranges and Cooktops))
by smithmr 7/23/2010 9:55:33 AM(UTC)
Bake Element Not Heating (Oven Repair (including Ranges and Cooktops))
by DelD 7/7/2010 8:58:54 AM(UTC)
bake element not heating but broil element heating okay (Oven Repair (including Ranges and Cooktops))
by horno 10/4/2009 8:28:00 AM(UTC)
Bake element not heating (Oven Repair (including Ranges and Cooktops))
by hdturrentine 1/19/2009 6:17:02 PM(UTC)
