dwksalist
#1 Posted : 14 years ago
dwksalist
We have a GE model # WJRR4170G2WW. The agitator doesnt turn during the wash cycle. Instead the whole drum rotates. Any help would be much appreciated.
#2 Posted : 14 years ago
Most likely the problem is a bad mode shifter (#320 on the diagram).
Remove the washer front panel and count the number of the signal LED flashes (under the motor's drip shield). Post the results.
You can find more useful information in one of our previous threads: http://forum.appliancepartspros...not-advance-agitate.html
Here are the breakdown diagrams and Replacement parts for General Electric WJRR4170G0WW Washer | AppliancePartsPros.com
dwksalist
#3 Posted : 14 years ago
dwksalist
Gene,
The LED flashes four times.
dwksalist
#4 Posted : 14 years ago
dwksalist
Thank You
dwksalist
#5 Posted : 14 years ago
Sorry for the delay.
Four blinks means that the mode shifter coils failed. The correction is to replace the mode shifter.
