sbolanos
#1 Posted : Thursday, October 30, 2008 9:21:42 AM(UTC)
sbolanos
MY OVEN IS NOT WOKRING!!! I went to bake some cobbler and turned on my oven and went to put it in and my oven was COLD!:mad: I thought maybe it was the igniter and I got down to the broiler and tried to light it with a lighter and still nothing. :mad: :mad: I think :confused: I can smell gas but I am not sure. Hubby, who is a roofer not a repair man, thinks it could be the safety valve.:cool: I would really like to know what it really could be and not just :confused: GUESS :confused: at the problem. I would be so greatful:) if someone would be able to tell me what this could be without spending a ton of money. For 400 bucks, I can get a new one.
v2k04
#2 Posted : Thursday, October 30, 2008 9:26:54 AM(UTC)
v2k04
The ignitor is probably bad it should glow red hot and draw 3.2-3.6 amps to open the valve With electronic ignitor trying to light it with a lighter will never work.
sbolanos
#3 Posted : Thursday, October 30, 2008 9:29:01 AM(UTC)
sbolanos
Thanks. I will try that first. Do you have that part number?
libertyappl
#4 Posted : Thursday, October 30, 2008 9:31:17 AM(UTC)
libertyappl
Here's the breakdown of your unit. Model JGBS04PEA2WH
If you are smelling gas then I would say the ignitor is not getting hot enough to light the gas. Unfortuneately you can not light an oven like this with a lighter.
Nat
GE XL44 oven woes: temp knob fell out, how to remove cover? (Oven Repair (including Ranges and Cooktops))
by cyberdingo 4/29/2024 8:32:15 PM(UTC)
GE XL44 Gas Range - Oven Turns On by Itself (Oven Repair (including Ranges and Cooktops))
by keywiz77 2/27/2022 9:32:21 AM(UTC)
Ge Xl44 (Oven Repair (including Ranges and Cooktops))
by amyk1210 7/8/2015 4:48:42 AM(UTC)
GE XL44 oven 3/4" gap with door closed (Oven Repair (including Ranges and Cooktops))
by mrz80 4/28/2015 7:31:51 AM(UTC)
GE XL44 Burner Pre-Ignition??? (Oven Repair (including Ranges and Cooktops))
by USCGcpo 12/14/2014 5:01:34 PM(UTC)
GE XL44 Random Sparking (Oven Repair (including Ranges and Cooktops))
by USCGcpo 12/4/2014 2:41:37 PM(UTC)
GE XL44 oven control, clock, timer are out (Oven Repair (including Ranges and Cooktops))
by lisan222 10/25/2014 3:52:07 PM(UTC)
Oven temperature Control on GE XL44 B (Oven Repair (including Ranges and Cooktops))
by Kpaul 1/14/2013 1:28:20 PM(UTC)
GE XL44 Gas Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Vinnyboy6527 12/17/2012 12:17:27 PM(UTC)
GE XL44 Oven lights, but flame is small. Wont reach Temp (Oven Repair (including Ranges and Cooktops))
by dp2763 12/3/2012 12:43:28 PM(UTC)
GE XL44 Gas oven not firing (Oven Repair (including Ranges and Cooktops))
by Joe Mitch 10/16/2012 11:43:18 AM(UTC)
Ge xl44 oven not working (Oven Repair (including Ranges and Cooktops))
by Jcball 9/7/2012 1:48:59 PM(UTC)
ge xl44 regulator conversion mystery (Oven Repair (including Ranges and Cooktops))
by tom_mi 9/5/2012 5:14:53 AM(UTC)
Ge XL44 smell of gas, oven not lighting up quickly (Oven Repair (including Ranges and Cooktops))
by MKrieck 7/22/2012 6:40:21 PM(UTC)
GE XL44 Preheats but won't maintain! (Oven Repair (including Ranges and Cooktops))
by timmy68 7/4/2012 4:00:43 PM(UTC)
