amyk1210
#1 Posted : Wednesday, July 8, 2015 4:48:42 AM(UTC)
amyk1210
Hi, our oven is taking nearly 25-30+ minutes to get up to 350 degrees. I have read over some of the older posts, but can't determine from those if it is my sensor or other another issue (their models were not the same as mine).
Any suggestions?
thank you!
Simon / APP Team
#2 Posted : Wednesday, July 8, 2015 12:53:55 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
After the oven gets to 350 degrees does it take longer then usual to cook? Time how long it takes to ignite the gas after the bake ignitor start to glow.
Here are the breakdown diagrams and parts for your oven
Model JGBP90MEB5BC
Thank you,
Simon.
amyk1210
#3 Posted : Wednesday, July 8, 2015 4:14:36 PM(UTC)
amyk1210
I timed it from time to start to the time it took to light and was around 3 minutes. My wife says yes, it has begun taking longer to cook (but maybe because it took longer to light?). I don't have any numbers (should have taken 1 hour but instead took 1.5 hours). But overall comment was yes it takes longer than it should.
Simon / APP Team
#4 Posted : Wednesday, July 8, 2015 4:37:20 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
In that case you need to replace the bake ignitor
Part number: AP2020569
Unplug the range before any repairs. Use a wet sponge to drop some water on the top of the screws that holds the ignitor, it will make a huge difference when you will attempt to take those screws out.
Here are the breakdown diagrams and parts list for your range:
Model JGBP90MEB5BC
Good luck. Please keep us posted with the results.
Thank you,
Simon.
amyk1210
#5 Posted : Sunday, July 12, 2015 12:48:44 PM(UTC)
amyk1210
I installed the new ignitor and worked like a champ. One advice for those with similar units. In your video it showed I needed to take off the back panel to access the quick release. However, on my unit it was accessible by removing the warming bin underneath (we story extra backing pans in it). From there I could quick disconnect it and follow the directions. 15 minute fix (from pulling it away from the wall to putting it back). thanks again!!!!
GE XL44 oven woes: temp knob fell out, how to remove cover? (Oven Repair (including Ranges and Cooktops))
by cyberdingo 4/29/2024 8:32:15 PM(UTC)
GE XL44 Gas Range - Oven Turns On by Itself (Oven Repair (including Ranges and Cooktops))
by keywiz77 2/27/2022 9:32:21 AM(UTC)
GE XL44 oven 3/4" gap with door closed (Oven Repair (including Ranges and Cooktops))
by mrz80 4/28/2015 7:31:51 AM(UTC)
GE XL44 Burner Pre-Ignition??? (Oven Repair (including Ranges and Cooktops))
by USCGcpo 12/14/2014 5:01:34 PM(UTC)
GE XL44 Random Sparking (Oven Repair (including Ranges and Cooktops))
by USCGcpo 12/4/2014 2:41:37 PM(UTC)
GE XL44 oven control, clock, timer are out (Oven Repair (including Ranges and Cooktops))
by lisan222 10/25/2014 3:52:07 PM(UTC)
Oven temperature Control on GE XL44 B (Oven Repair (including Ranges and Cooktops))
by Kpaul 1/14/2013 1:28:20 PM(UTC)
GE XL44 Gas Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Vinnyboy6527 12/17/2012 12:17:27 PM(UTC)
GE XL44 Oven lights, but flame is small. Wont reach Temp (Oven Repair (including Ranges and Cooktops))
by dp2763 12/3/2012 12:43:28 PM(UTC)
GE XL44 Gas oven not firing (Oven Repair (including Ranges and Cooktops))
by Joe Mitch 10/16/2012 11:43:18 AM(UTC)
Ge xl44 oven not working (Oven Repair (including Ranges and Cooktops))
by Jcball 9/7/2012 1:48:59 PM(UTC)
ge xl44 regulator conversion mystery (Oven Repair (including Ranges and Cooktops))
by tom_mi 9/5/2012 5:14:53 AM(UTC)
Ge XL44 smell of gas, oven not lighting up quickly (Oven Repair (including Ranges and Cooktops))
by MKrieck 7/22/2012 6:40:21 PM(UTC)
GE XL44 Preheats but won't maintain! (Oven Repair (including Ranges and Cooktops))
by timmy68 7/4/2012 4:00:43 PM(UTC)
GE XL44 gas oven not achieving set temperature (Oven Repair (including Ranges and Cooktops))
by wambo 6/20/2012 3:57:03 PM(UTC)
