Hi, our oven is taking nearly 25-30+ minutes to get up to 350 degrees. I have read over some of the older posts, but can't determine from those if it is my sensor or other another issue (their models were not the same as mine).
Any suggestions?
thank you!
Groups: APP Team
Hi. After the oven gets to 350 degrees does it take longer then usual to cook? Time how long it takes to ignite the gas after the bake ignitor start to glow. Here are the breakdown diagrams and parts for your oven Model JGBP90MEB5BC
Thank you, Simon.
I timed it from time to start to the time it took to light and was around 3 minutes. My wife says yes, it has begun taking longer to cook (but maybe because it took longer to light?). I don't have any numbers (should have taken 1 hour but instead took 1.5 hours). But overall comment was yes it takes longer than it should.
Groups: APP Team
Hi. In that case you need to replace the bake ignitor Part number: AP2020569
Unplug the range before any repairs. Use a wet sponge to drop some water on the top of the screws that holds the ignitor, it will make a huge difference when you will attempt to take those screws out. Here are the breakdown diagrams and parts list for your range: Model JGBP90MEB5BC
Good luck. Please keep us posted with the results. Thank you, Simon.
I installed the new ignitor and worked like a champ. One advice for those with similar units. In your video it showed I needed to take off the back panel to access the quick release. However, on my unit it was accessible by removing the warming bin underneath (we story extra backing pans in it). From there I could quick disconnect it and follow the directions. 15 minute fix (from pulling it away from the wall to putting it back). thanks again!!!!
