potsandpans
#1 Posted : Sunday, April 10, 2011 12:10:06 PM(UTC)
potsandpans
am not getting water in my dishwasher. have water to valve but not coming thru valve and into washer. on the valve there is a switch that reads 3min on 8min off. could that be problem?? if not what can i do to diagnose problem? thanks:confused:
#2 Posted : Sunday, April 10, 2011 12:55:19 PM(UTC)
Replacement parts for General Electric GLD4100M15WW Dishwasher | AppliancePartsPros.com
Not sure what the label means, probably just cycle time spec.
Measure across the valve when it should be getting voltage.
Check the float on the overfill assembly. Sometimes it can get stuck in the up position. If it is then usually cleaning it will fix the problem.
If the overfill switch is being activated, check for 120 volts across the fill valve when it should be on.
If there is no voltage, check across the fill valve/overfill switch (they are wired in series).
If there is no voltage there, then the control board is probably toast or you have a bad wire.
If there is voltage, then check across the overfill switch. If there is voltage across the switch then the switch is shot.
If there is 120 volts across the fill valve then either the fill valve needs replacing or it's filter needs cleaning.
There is a screen filter built into the input side of the valve. Remove the valve from the unit and check/clean the screen filter.
Do not permanently remove the screen filter from the valve as it is there to keep crud out of the valve which could hold it open and cause a flood.
potsandpans
#3 Posted : Monday, April 11, 2011 9:44:55 AM(UTC)
potsandpans
thanks for info. will follow your advice and let you know
GE Quietpower 3 - Was Leaking at Door, Now No Water (Dishwasher Repair)
by aheroncrew 12/6/2023 1:02:46 PM(UTC)
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
no water dispensing out of door (Refrigerator & Freezer Repair)
by montyrt@gmail.com 4/2/2023 9:08:51 AM(UTC)
No Ice No Water on LG LFX21960ST Refrig (Refrigerator & Freezer Repair)
by jvc57 3/3/2023 4:42:12 AM(UTC)
Kitchenaid no water in icemaker unless jumper valve control then fills till jumper removed and eject (Refrigerator & Freezer Repair)
by Guest 5/15/2022 6:57:18 AM(UTC)
LG lfx31945 no water (Refrigerator & Freezer Repair)
by azurebat 11/29/2021 2:45:31 PM(UTC)
Water dispenser has no water but gushes inside fridge compartment when activated (Refrigerator & Freezer Repair)
by xclr8 11/20/2021 12:39:21 PM(UTC)
Ice maker arm works, but no water (Refrigerator & Freezer Repair)
by dean8433 11/16/2021 10:05:30 AM(UTC)
Maytag Washer - no water (Washer Repair)
by maalfunction 11/2/2021 6:52:56 AM(UTC)
GE Refrigerator #GSHS5KGXBCSS No water and loud noise after filter replacement (Refrigerator & Freezer Repair)
by Guest 8/26/2021 6:48:33 PM(UTC)
Ice Maker Receiving No Water (Refrigerator & Freezer Repair)
by tibrbk 5/31/2021 10:19:02 AM(UTC)
no water getting to ice maker but water dispenser works (Refrigerator & Freezer Repair)
by bdevlin 1/11/2021 2:18:45 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
8 yr old Whirlpool no ice & no water. Replacing filter every 2 months (Refrigerator & Freezer Repair)
by robodell100 9/5/2020 4:57:43 PM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
