OhioLad
#1 Posted : 14 years ago
OhioLad
How do I remove the front panel (part # 10) to replace the timer?
Thank you
sidfink43
#2 Posted : 14 years ago
sidfink43
Use a wide putty knife and slide it under the end caps from the front to release clips that hold the console to the cabinet. It will flip up and you can get to the timer to replace it.
OhioLad
#3 Posted : 14 years ago
OhioLad
Thank you.
That worked perfectly!
sidfink43
#4 Posted : 14 years ago
sidfink43
Great, sometimes getting those clips released is a little tricky, so glad you got to it.
Thanks for the update also.
Dryer timer replacement help (Dryer Repair)
by Guest 9 months ago
Defrost timer replacement (Refrigerator & Freezer Repair)
by Joe Calypso 11 years ago
Timer Replacement (Dryer Repair)
by Stevesframes 12 years ago
Whirlpool dryer will not shut off after new timer replacement (Dryer Repair)
by grayfeathers 12 years ago
timer replacement (Washer Repair)
by garybo 12 years ago
Oven Timer replacement (Oven Repair (including Ranges and Cooktops))
by keith54 12 years ago
dryer timer replacement (Dryer Repair)
by samroyster 13 years ago
Amana bottom freezer defrost timer replacement (Refrigerator & Freezer Repair)
by blackketter 13 years ago
GE washer timer replacement (Washer Repair)
by spoling 13 years ago
Whirlpool washer timer replacement (Washer Repair)
by kurtvance 13 years ago
Timer replacement (Washer Repair)
by Steve Berenyi 13 years ago
Whirlpool Timer Replacement (Washer Repair)
by Jeff II 14 years ago
washing machine timer replacement and install (Washer Repair)
by danny123 14 years ago
Washer Timer Replacement (Washer Repair)
by kgr30161 14 years ago
Whirlpool timer replacement (Washer Repair)
by juliemeyer01 14 years ago
