I checked my Defrost Heater and got a reading of 20 ohms, I then read thru the Thermostat and Heater and got the same reading. The unit had been running and I took the cover from the back of freezer pulled the connector plug so everything was cold. Is that a good reading or is something in error.
That apprears t be a good reading. Did you check adaptable defrost module? Exatly what is your unit doing? Nat
The same question about freezer running ok and the refrigerator getting warm, thanks for info. I think the adaptive defrost is going to be the problem and will go ahead and replace it.....
If memory serves the part number is 61005988. Nat
