rick12
#1 Posted : Tuesday, October 28, 2008 8:47:17 AM(UTC)
rick12
I checked my Defrost Heater and got a reading of 20 ohms, I then read thru the Thermostat and Heater and got the same reading. The unit had been running and I took the cover from the back of freezer pulled the connector plug so everything was cold. Is that a good reading or is something in error.
libertyappl
#2 Posted : Tuesday, October 28, 2008 9:33:56 AM(UTC)
libertyappl
That apprears t be a good reading. Did you check adaptable defrost module? Exatly what is your unit doing?
Nat
rick12
#3 Posted : Tuesday, October 28, 2008 9:48:04 AM(UTC)
rick12
The same question about freezer running ok and the refrigerator getting warm,
thanks for info. I think the adaptive defrost is going to be the problem and will go ahead and replace it.....
libertyappl
#4 Posted : Tuesday, October 28, 2008 10:31:52 AM(UTC)
libertyappl
If memory serves the part number is 61005988.
Nat
Guest (5)
Defrost heater and thermostat (Refrigerator & Freezer Repair)
by Servicer123456 10/30/2016 8:05:46 AM(UTC)
