dk1115
#1 Posted : Wednesday, April 6, 2011 1:36:52 PM(UTC)
dk1115
My temperature control will only let me wash hot and rinse hot. Wont allow cold water to come into machine.
sidfink43
#2 Posted : Thursday, April 7, 2011 5:16:10 PM(UTC)
sidfink43
Well I do not understand how you are getting a hot rinse, since I don't think that is an option on this, or just about any other model. If you are getting hot water in the rinse cycle then it can be the water temp switch, the timer, the valve assembly or this part here particularly if you are getting hot water in the wash cycle when you have it set on cold water for wash.
Part number: AP4028021
My vote is for that board, but you will have to try replacing it to confirm that.
dk1115
#3 Posted : Friday, April 8, 2011 2:10:58 PM(UTC)
dk1115
thanks sid.
I can NOT get any cold water to machine from any setting. Just replaced temp switch and still doing the same thing,
Donna
#4 Posted : Friday, April 8, 2011 4:39:53 PM(UTC)
Just to add my 2 cents...
Donna,
Did you check the incoming water hoses? They could be switched around.
dk1115
#5 Posted : Sunday, April 10, 2011 10:27:34 AM(UTC)
dk1115
Donna,
Done that. The cold water side of the valve doesn't seem to be getting enough voltage to open. Does that come from the circuit board?
sidfink43
#6 Posted : Sunday, April 10, 2011 11:20:40 AM(UTC)
sidfink43
The board controls voltage to the valves. Take a look at the wiring diagram and you will see how it flows.
Wiring information replacement parts for MAYTAG MAV7000AWW WASHER, ATLANTIS | AppliancePartsPros.com
Guest (4)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
