cmhusker
#1 Posted : Monday, October 27, 2008 3:38:34 PM(UTC)
cmhusker
I have a roper by whirlpool electric range. The oven does not work, and the burners will not get to high heat. What could be wrong?
libertyappl
#2 Posted : Monday, October 27, 2008 6:08:42 PM(UTC)
libertyappl
Please post your model number.
Nat
cmhusker
#3 Posted : Sunday, November 2, 2008 6:22:22 PM(UTC)
cmhusker
Model number FEP310KW.
libertyappl
#4 Posted : Monday, November 3, 2008 3:23:50 AM(UTC)
libertyappl
For starters, if it is less than a year old as posted above call a Whirlpool tech for repair.
kayakcrzy
#5 Posted : Monday, November 3, 2008 4:59:40 AM(UTC)
kayakcrzy
Go and flip your breaker off and on a few times, and see if the oven will work. You will most likely have a power problem, or a burn't wire on the terminal block where the cord comes in. Tom ApplianceEducator.com
cmhusker
#6 Posted : Thursday, November 6, 2008 6:01:47 AM(UTC)
cmhusker
It is about 1.5 years old... I flipped the breakers, still the same. I took the back panel off and discovered that my 8" burner switch has burnt marks on it. I didn't see any signs of burnt wires. Any other advice?
abadfish66
#7 Posted : Thursday, November 6, 2008 6:22:48 AM(UTC)
abadfish66
make sure you have 240 volts at the wall outlet, and at the terminal block like stated above. Almost always a power problem when the whole oven wont heat up properly.
kayakcrzy
#8 Posted : Thursday, November 6, 2008 1:43:44 PM(UTC)
kayakcrzy
If we go back to your original post, it sounds like not enough power. You could have a problem with that switch, but you stated that the burners will not get to high heat, and the oven does not work. If that one switch is bad, it won't make the oven work. I think you still have a power problem. If you don't have a meter you are guessing. Also Nat had suggested that if the oven is under a year old, you need to call the warranty people. Tom ApplianceEducator.com
cmhusker
#9 Posted : Tuesday, November 18, 2008 5:11:16 AM(UTC)
cmhusker
Thanks guys! It was a bad breaker and the terminal block was fried. Installed new breaker and terminal block and it works like a champ!
abadfish66
#10 Posted : Tuesday, November 18, 2008 5:16:40 AM(UTC)
abadfish66
Sweet :) Good fixin
Could someone please help me fix my washer (Washer Repair)
by HopelessNKY 7/28/2022 3:00:04 PM(UTC)
KitchenAid Artisan unknown problem. Please help! (Blender Repair)
by fakupos 5/17/2022 8:00:10 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
please help kitchen aid fridge noise (Refrigerator & Freezer Repair)
by marcelmcesar 8/3/2021 4:54:39 PM(UTC)
Admiral ss fridge freezer damper door freezing open Please help (Refrigerator & Freezer Repair)
by swingbyte 4/1/2021 11:35:24 PM(UTC)
Fisher & Paykel DEIX2 Dryer Keeps tripping t-stat Please Help (Dryer Repair)
by hotlicksexhaust 5/7/2020 8:22:39 AM(UTC)
Silence is definitely not Golden (LG) ... Please help (Microwave Repair)
by benh1234 1/16/2019 2:13:22 PM(UTC)
Please Help - Whirlpool WFG524SLAS (Oven Repair (including Ranges and Cooktops))
by yozzomp 12/5/2018 1:27:04 PM(UTC)
Cant remove metal tub old Whirlpool/ Kitchen Aide Washer Please Help! (Washer Repair)
by robertgarven 3/23/2018 2:24:04 PM(UTC)
Mystery part loose in box - please help identify! (Refrigerator & Freezer Repair)
by xkandakex 12/14/2017 10:36:27 AM(UTC)
PLEASE HELP! Quiet Partner III Cancel, Rinse Only Lights Blinking (Dishwasher Repair)
by zed40 3/24/2017 6:16:49 PM(UTC)
Please Help,GE Fridge Water not dispensing and other issues. # PSS25MGMAWW (Refrigerator & Freezer Repair)
by c.marvin077 2/11/2017 8:02:28 AM(UTC)
Oven and display not working...please help. (Oven Repair (including Ranges and Cooktops))
by LJ44 2/5/2017 8:12:19 AM(UTC)
Please HELP!!! My dryer is not heating. (Dryer Repair)
by Anonpirate 7/28/2016 11:44:39 PM(UTC)
Please help with my GE replacement motor wiring (Dryer Repair)
by Mjutton 6/29/2016 7:36:12 PM(UTC)
