Jon P
#1 Posted : Friday, October 24, 2008 3:46:41 PM(UTC)
Jon P
A short time ago, I replaced the thermal fuse for a no heat problem. It was working good until today. I checked and found the thermal cutout bad this time. The red (with white) wire also got hot near the cutout. Is it possible I have a problem with the heating element? Or should I just replace the cutout and the t-stat? Thanks for any help.
#2 Posted : Saturday, October 25, 2008 3:53:41 PM(UTC)
Hi Jon,
I would recommend to replace the thermal cut-off together with the high-limit thermostat and make sure there is no restrictions in the vent lines.
Here are the break down diagrams for the Whirlpool dryer Model LER7646DQ1
Jon P
#3 Posted : Saturday, October 25, 2008 5:00:29 PM(UTC)
Jon P
Thanks,
I got the parts today and the cutoff and t-stat come together. I took the lint chute off and found it half plugged up down by the blower. I hope that is all that it is.
v2k04
#4 Posted : Saturday, October 25, 2008 5:29:34 PM(UTC)
v2k04
While your there also check for the element to be shorted to ground which they always do which would also blow the limit just take your mutimeter set to ohms and go from each elemnt terminal to the outside casing on heat element housing if you get a reading the wires on the element is touching They dont always burn in two but instead weld themselves to the tin and causing a short circuit.
Jon P
#5 Posted : Saturday, October 25, 2008 5:34:06 PM(UTC)
Jon P
Thanks,
As long as I had it apart, I put in a new element also. Good info for future reference, Thanks again.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
