mrsakman
#1 Posted : Wednesday, October 22, 2008 7:19:36 PM(UTC)
mrsakman
I've just taken mywasher apart only to find a sock inside the drum part that wouldn't let it spin. Problem solved!
But I've hooked up everything only to find that a harness that has a red, white and blue wire is not hooked up. I can't remember if it was hooked up before. However, my dryer has no error codes.
but when I try to start a cycle, I don't hear the water solenoids kick in and let in water and the drum doesn't spin. Is there any troubleshooting guides or prints to show me where to look next?:confused:
#2 Posted : Thursday, October 23, 2008 6:43:56 PM(UTC)
Remove the bottom panel and look for an envelope with the wiring diagram.
Frigidaire Affinity front loader code (Washer Repair)
by Volusiacrazy 5/1/2024 3:26:17 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Washer leak Frigidaire Affinity (Washer Repair)
by Guest 10/23/2023 1:59:44 PM(UTC)
Control board for Frigidaire Affinity dryer (E68 error code) (Appliance Parts)
by VanFramez 12/18/2022 11:57:30 AM(UTC)
Frigidaire Affinity Dryer, seem stuck on high heat (Dryer Repair)
by GoldToyBox 4/29/2022 4:53:20 PM(UTC)
Frigidaire Affinity NO START, the light is not on when the door is open (Dryer Repair)
by Guest 3/13/2022 9:02:49 PM(UTC)
frigidaire affinity dryer LEQ6000es2 Stuck in mode (Dryer Repair)
by Guest 7/13/2021 5:25:53 AM(UTC)
Frigidaire Affinity Noise when filling (Washer Repair)
by PaganJim 4/3/2021 8:52:05 AM(UTC)
2011 Frigidaire Affinity Dryer (Dryer Repair)
by Donnchad 11/1/2020 3:01:12 PM(UTC)
Frigidaire affinity dryer model number fase7073a2 (Dishwasher Repair)
by Ann P 7/28/2020 7:31:25 PM(UTC)
Frigidaire Affinity Dryer AGQ6700FS2 (Dryer Repair)
by moh 7/8/2020 3:29:08 PM(UTC)
Frigidaire Affinity door sag (Washer Repair)
by KDub 4/3/2020 12:40:23 PM(UTC)
Frigidaire affinity no heat (Dryer Repair)
by humonculi 2/18/2020 2:00:03 PM(UTC)
Frigidaire affinity stops running, lights blinking, no heat (Dryer Repair)
by klindquist 10/17/2019 2:25:58 PM(UTC)
Frigidaire Affinity Washer not final spin (Washer Repair)
by Jcrosslin 10/16/2019 7:21:36 AM(UTC)
