AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Frigidaire Affinity Dryer, seem stuck on high heat
Our Frigidaire Affinity Dryer, Mod FAQE 7077 KWO, seems to be stuck on High Heat. I haven't found a schematic on the unit or in my paperwork. Is there one inside the unit or one available online? Any thoughts on what to check first? (the vent is clear) I placed the unit on "no heat/Fluff" and still have heat.
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395  Location: near the middle of nowhere Was thanked: 19 time(s) in 19 post(s)
Just to follow up, everything ohm'ed OK except the heater coils which showed no continuity. Found coil broken and steel board holding the coils melted (it's a wonder it didn't catch fire. Replaced heater assembly (checked continuity OK before installing) Now my problem is no heat, so the mystery continues
Dryer Repair
