danonezag
#1 Posted : Tuesday, October 21, 2008 10:39:28 AM(UTC)
danonezag
microwave does not heat up- all else works- lights, turntable, control pad,
what part should i order??
thanks
dan
v2k04
#2 Posted : Tuesday, October 21, 2008 10:50:50 AM(UTC)
v2k04
It could be a number of different things. Mag.diode.capacitor, x-former,thermal fuse,control board, One needs to trobleshoot it on site and go through the process It will make different sounds depending on what componant went badEach one has it's own distint noise in a sense. open the control panel and dig out the tech data sheet there will be info on how to check it out be sure to unplug & discharge the capacitor before you go probing around LOTS OF HI-VOLTAGE in there.
Microwave repair (Microwave Repair)
by Tim Swanson 11/20/2013 1:20:16 PM(UTC)
by Burde Kamath 2/11/2013 4:08:13 AM(UTC)
Is this microwave repairable (Microwave Repair)
by kalt 12/31/2012 9:41:35 AM(UTC)
Microwave Repair (Microwave Repair)
by ramara 12/4/2012 1:13:52 PM(UTC)
microwave repair help (Microwave Repair)
by dia 10/1/2012 1:08:16 PM(UTC)
by gskill@bellsouth.net 8/1/2012 3:21:05 AM(UTC)
by JO D 12/11/2011 4:17:55 AM(UTC)
by DANLUDLOW 11/28/2011 7:28:09 AM(UTC)
microwave repair (Microwave Repair)
by cking1269 11/4/2011 9:04:36 AM(UTC)
kenmore microwave repair (Microwave Repair)
by ploou 11/3/2011 10:42:00 AM(UTC)
GE microwave repair help (Microwave Repair)
by Tom in Crozet 4/28/2011 7:07:55 PM(UTC)
Microwave Repair with loud noise (Microwave Repair)
by Faith4220 12/26/2010 11:20:14 AM(UTC)
by stillyrabbit 12/22/2010 10:52:18 AM(UTC)
by bloop 11/4/2010 8:33:04 AM(UTC)
Is old microwave repairable? (Microwave Repair)
by sadiehaflinger 11/17/2009 9:51:36 AM(UTC)
