Mike.M
#1 Posted : Wednesday, August 20, 2008 10:14:37 AM(UTC)
Mike.M
I have a GE XL44 stove that the oven recently stopped working. There was a strong odor of gas. I took out the bottom tray and turned the oven on, the igniter was glowing and the burners did light up. I reassembled the oven and it worked for a couple more weeks and then failed to light again with a strong gas odor. It appears the igniter is working, do I need to replace it or something else?
abadfish66
#2 Posted : Wednesday, August 20, 2008 10:36:00 AM(UTC)
abadfish66
Measure the resistance of the glow bar. A good glowbar will read between 50-150 ohms.
Mark Hatfield
#3 Posted : Monday, October 20, 2008 4:13:41 PM(UTC)
Mark Hatfield
I have a GEXL44 Profile. The oven will not light. I hear no gas. I have taken the panel off. The burners on top work. The broiler does not turn on either.
#4 Posted : Monday, October 20, 2008 6:26:30 PM(UTC)
Hi Mark,
What is the complete model number of the range?
Mark Hatfield
#5 Posted : Monday, October 20, 2008 7:59:24 PM(UTC)
Mark Hatfield
Model Number JGBP90ME A2BC
#6 Posted : Tuesday, October 21, 2008 2:01:27 PM(UTC)
Most likely the problem is a bad Bake igniter. In order to access the part remove the oven floor, the flame spreader and the bottom drawer.
- The part number for the igniter is AP2014008
Here are the break down diagrams for the GE range Model JGBP90MEA2BC
