I have a GE XL44 stove that the oven recently stopped working. There was a strong odor of gas. I took out the bottom tray and turned the oven on, the igniter was glowing and the burners did light up. I reassembled the oven and it worked for a couple more weeks and then failed to light again with a strong gas odor. It appears the igniter is working, do I need to replace it or something else? Thanks
Measure the resistance of the glow bar. A good glowbar will read between 50-150 ohms.
I have a GEXL44 Profile. The oven will not light. I hear no gas. I have taken the panel off. The burners on top work. The broiler does not turn on either.
Hi Mark,
What is the complete model number of the range?
Originally Posted by: Mark Hatfield  I have a GEXL44 Profile. The oven will not light. I hear no gas. I have taken the panel off. The burners on top work. The broiler does not turn on either. Model Number JGBP90ME A2BC
Most likely the problem is a bad Bake igniter. In order to access the part remove the oven floor, the flame spreader and the bottom drawer. - The part number for the igniter is AP2014008 Here are the break down diagrams for the GE range Model JGBP90MEA2BCGene.
