Ryeberto
#1 Posted : Monday, October 20, 2008 6:19:28 PM(UTC)
Ryeberto
My washer spins only intermittently. The first time I was left with a batch of soggy unspun clothes a repairman replaced the pump. (the water did pump out). The pump gasket did have an aneurism so maybe it was damaged. The washer worked fine for one week. Then it refused to spin out the water a second time. This time there was a strong smell of rubber accompanying the malfunction. The same repairman returned today: when he first tried the washer, it would not spin. Next, he removed the casing and the machine worked perfectly every time for 5 times. His diagnosis? Faulty transmission. Whirlpool is sending me a transmission at 50% of their cost. Now--what if the repairman is wrong? Could the timer be faulty or is there just no way to know??? The washer is five years and three months old.
Should I just return the transmission when it arrives and buy a new washer? The first repair cost $167.00 ($100.00 was labor). The repairman will charge me $45.00 to install the transmission if I decide to go ahead with the repair.
Please advise. Thank You for your time. R. Taylor
#2 Posted : Tuesday, October 21, 2008 1:16:45 PM(UTC)
Originally Posted by: Ryeberto Go to Quoted Post
...when he first tried the washer, it would not spin...
Did the motor run at this time?
Ryeberto
#3 Posted : Tuesday, October 21, 2008 5:41:46 PM(UTC)
Ryeberto
Yes, the machine seemed to run completely through the cycle every time. But twice it did not spin. R. Taylor
#4 Posted : Tuesday, October 21, 2008 10:41:23 PM(UTC)
It's hard to say what is better: to fix it or to get a new one. If you decided to fix it, I would recommend to replace the clutch and the motor drive coupling together with the transmission. These parts have to be removed anyway and to have them new will make the repair more dependable.
- The part number for the clutch is AP3094537
- The part number for the motor drive coupling is AP3963893
Here are the break down diagrams for the Whirlpool washer Model LSB6300LW0
Ryeberto
#5 Posted : Wednesday, October 22, 2008 10:04:33 AM(UTC)
Ryeberto
Thank you for the rapid response. I shall heed your advice. R. Taylor
Samsung Washer does not spin (Washer Repair)
by SwimKatie 3/22/2016 5:51:48 PM(UTC)
Frigidaire Front Washer does not spin - intermittent issue (Washer Repair)
by jamesm113 6/23/2015 9:13:55 PM(UTC)
Kenmore 90 washer does not spin (Washer Repair)
by ChdoulaDIY 5/31/2015 1:39:29 AM(UTC)
by RoyD 10/15/2014 10:24:49 AM(UTC)
Washer does not spin or agitate (Washer Repair)
by bluebomb 8/8/2013 4:55:43 AM(UTC)
washer does not spin or agitate (Washer Repair)
by Dustycopper 2/10/2013 1:49:54 PM(UTC)
Stackable washer does not spin or drain (Washer Repair)
by North Dakota 1/23/2013 7:00:40 PM(UTC)
by isagrace 1/23/2013 9:40:41 AM(UTC)
GE Profle Washer Does Not Spin (Washer Repair)
by cclemm 11/13/2012 7:56:17 AM(UTC)
Amana Washer Does Not Spin (Washer Repair)
by sfrane 10/29/2012 11:21:24 PM(UTC)
Washer does not spin anymore just normal draining speed (Washer Repair)
by Herbert Engelmayer 9/13/2012 1:29:52 PM(UTC)
maytag washer does not spin fast after rinse cycle (Washer Repair)
by pepito 6/28/2012 3:31:14 PM(UTC)
frount load washer does not spin to full speed (Washer Repair)
by ranger11986 6/12/2012 3:07:50 PM(UTC)
washer does not spin/agitate (Washer Repair)
by jetson2k 5/7/2012 2:31:02 PM(UTC)
washer does not spin/wash clothes (Washer Repair)
by leonitise 1/28/2012 9:17:45 PM(UTC)
