Herbert Engelmayer
#1 Posted : Thursday, September 13, 2012 1:29:52 PM(UTC)
Herbert Engelmayer
There was considerable spinning sound for a while - washing drum sort of wobbling while spinning (motor bearing ? ) then gave up spinning - only regular draining speed available- fast spin does not kick-in, anymore.
What can I do ?
Simon / APP Team
#2 Posted : Thursday, September 13, 2012 2:17:41 PM(UTC)
Simon / APP Team
Groups: APP Team
hi.
Raise the top (2 clips in the corners), remove the front panel and check if the motor is gliding on the motor plate when switching from agitation to spin. See if by pushing on the motor you can increase the speed.
Check the belt traction, motor speed.
Here are the breakdown diagrams and Replacement parts for Amana NAV5805AWW WASHER-TOP LOADING | AppliancePartsPros.com
Post the results.
Simon.
Guest (5)
