Originally Posted by: MEISHKA30  I Have A Maytag Neptune Dryer And It Does Not Heat Up,i Need A Repair Manual And Can Not Find One,someone Please Help Me Find One. Meishka, We can only reccomend you contact the manufacturer for a service manual. First, if you haven't yet, check and make sure both breakers are set and supplying 220 VAC at the wall outlet. We'll be more than happy to assist, and supply any information you need to correct the problem with your dryer. :) :) :)
