My washer will fill, wash and spin, but it doesn't drain completely unless I send it thru for a second time. It also doesn't fill up on cold water ( valve is open).
Any help with what could be the problem(s) is appreciated.
Check the valve screen for debris, also check to see if the washer is spinning fast enough. You may also want to see if there is an obstruction in the pump. Here's a breakdown of your machine Model LAT9205AAE Nat
