Drain hose filters and screens are all clear, no blockages as far as I can see. Does not have an air gap replaced Piston and nut assembly. goes into drain cycle but only drains about 1 gal and runs for about 20 seconds before it starts re-filling. Pump seems to be running fine and timer seems to be working ok.I'm at the end of my rope on this one.
Hi ynot
Did you see any indicator lights on the control panel blinking?
