kobeplace
#1 Posted : Monday, March 21, 2011 3:59:52 PM(UTC)
kobeplace
Ok I seem to have located the problem.. But I’m in need of assistance.. I removed the Belt and check all the pulleys, I notice the motor pulley rotates with some tension, and not smooth - I also notice that when I 1st tried to turn the motor pulley it was wedge against the metal of the washer.. So when I Tired to turn it - I t made this load squeaking noise, then stop turning.. Then when I move the motor away from the metal It turn freely but when I let it go - it gets wedge right back against the metal and Either turns slowly or not at all… how can I fix this problem with out buying new motor.
#2 Posted : Tuesday, March 22, 2011 3:21:41 AM(UTC)
Probably missing motor spring AP4027842, just look for it.
Maytag Dryer Motor Pulley and Belt Restrainer problem (Dryer Repair)
by PHL 5/27/2015 10:46:48 PM(UTC)
Motor Pulley Question (Washer Repair)
by scottfross 11/30/2014 7:20:40 AM(UTC)
Removal of motor pulley (Dryer Repair)
by Lydster22 8/30/2014 11:14:17 AM(UTC)
motor pulley broke off (Dryer Repair)
by katiebell2355 8/2/2014 9:31:08 AM(UTC)
Maytag Atlantis Motor Pulley (Washer Repair)
by hsvjz 6/14/2014 3:20:13 PM(UTC)
motor pulley rubs motor shaft (Dryer Repair)
by Travis7 6/9/2014 5:00:34 PM(UTC)
motor pulley broken (Washer Repair)
by sharoni70 11/5/2013 7:29:33 AM(UTC)
Whirlpool dryer motor pulley replacement question (Dryer Repair)
by herrbutzie 12/4/2012 8:56:07 AM(UTC)
how to replace motor pulley (Washer Repair)
by spurs fan 7/16/2012 8:40:55 AM(UTC)
motor pulley for belt (Dryer Repair)
by TITANICHISPANIC 1/9/2012 6:41:12 PM(UTC)
kenmore motor pulley/screw on or pressure mounted (Dryer Repair)
by meandjulio04 5/19/2011 8:21:40 AM(UTC)
Motor pulley shaved off (Washer Repair)
by msaeger 2/13/2011 6:49:18 PM(UTC)
Can't attach GE dryer belt to motor pulley (Dryer Repair)
by calphotoguy 1/14/2011 5:41:00 PM(UTC)
Maytag washer motor pulley broken. How do I fix? (Washer Repair)
by appliancekillerwife 9/28/2010 4:28:45 PM(UTC)
how to remove motor pulley? (Washer Repair)
by turchekj 8/11/2010 8:46:02 AM(UTC)
