End of cycle buzzer does not sounf at end of cycle. Is the buzzer bad or could it be something else?
I could be a loose wire on the buzzer or the buzzer itself, but if your unit is less than a year old call a certified tech for any repair so you don't void your warranty. Nat
Could you tell me where this buzzer is located on the dryer? Thank you.
It is in the control panel. Nat
Originally Posted by: libertyappl  It is in the control panel. Nat Thanks to you I found a spade clip on the buzzer not making good contact. You saved me a $75.00 service call. Thank you so much!
Glad you found the problem.! Nat
I have a kenmore dryer Model # 63942101 and want to sheck out the dryer buzzer. How can I remove the top panel?
