shishak
#1 Posted : Thursday, October 16, 2008 7:27:11 AM(UTC)
shishak
End of cycle buzzer does not sounf at end of cycle. Is the buzzer bad or could it be something else?
libertyappl
#2 Posted : Thursday, October 16, 2008 8:27:32 AM(UTC)
libertyappl
I could be a loose wire on the buzzer or the buzzer itself, but if your unit is less than a year old call a certified tech for any repair so you don't void your warranty.
Nat
shishak
#3 Posted : Thursday, October 16, 2008 9:41:07 AM(UTC)
shishak
Could you tell me where this buzzer is located on the dryer? Thank you.
libertyappl
#4 Posted : Thursday, October 16, 2008 10:23:45 AM(UTC)
libertyappl
It is in the control panel.
Nat
shishak
#5 Posted : Friday, October 17, 2008 5:23:02 AM(UTC)
shishak
Nat
Thanks to you I found a spade clip on the buzzer not making good contact. You saved me a $75.00 service call. Thank you so much!
libertyappl
#6 Posted : Friday, October 17, 2008 6:41:05 AM(UTC)
libertyappl
Glad you found the problem.!
Nat
william watson
#7 Posted : Monday, June 17, 2013 12:17:30 PM(UTC)
william watson
I have a kenmore dryer Model # 63942101 and want to sheck out the dryer buzzer. How can I remove the top panel?
Guest (4)
end of cycle buzzer (Dryer Repair)
by SherryR 3/25/2012 5:33:21 PM(UTC)
End of Cycle Buzzer doesn't work any longer. (Dryer Repair)
by kleinclan5 8/14/2010 5:38:37 AM(UTC)
End Of Cycle Buzzer Won't Stop (Dryer Repair)
by GHERRON 12/7/2009 7:45:57 AM(UTC)
End of Cycle Buzzer (Dryer Repair)
by keith418 8/7/2009 11:55:19 AM(UTC)
End of cycle buzzer (Dryer Repair)
by shishak 10/16/2008 7:25:19 AM(UTC)
