spiderman3d
#1 Posted : Thursday, October 16, 2008 2:01:42 PM(UTC)
spiderman3d
My washer is leaking from under the tub....and....I obviously have a bad bearing too. During the spin cycle we have to close the door to the utility room it is so loud...and water drains from under the tub. Anyway, I see no way to remove the agitator. There is a fabric softener cup on top of the agitator but I can find no way to remove it either.
libertyappl
#2 Posted : Thursday, October 16, 2008 2:16:26 PM(UTC)
libertyappl
The fabric softener cap comes off, may have to turn it. there is a screw under there the n you should be able to remove the agitator.
Nat
spiderman3d
#3 Posted : Friday, October 17, 2008 2:32:45 AM(UTC)
spiderman3d
Thank you for such a quick response. Okay....the fabric softener cup spins both ways and doesn't seem to unscrew or have a screw in it. The spiral portion of the agitator spins counter-clockwise but offers resistance being turned the clock-wise. Turning it clock-wise is hard but it doesn't seem to be unscrewing and will still freely turn counter-clockwise and offer resistance again when I turn it clock-wise. I have gotten a mirror and can find no screws in the agitator or the fabric softener cup. Does the fabric softener cup need to be pryed off the top of the agitator?
v2k04
#4 Posted : Friday, October 17, 2008 3:43:22 AM(UTC)
v2k04
I hate to be the bearer of bad news but your macnine is going to need a major overhaul tub seals spin bearing belt the other bad news is after you go to the trouble of fixing it with a minimum of 150 in parts it's just going to do the same thing in a couple years. You see Amana messed up with that machine and they used a plastic tub with the same or similar seals they used with the metal tubs, they found out that the plastic flexes and wont hold a tub seal for very long you are money ahead getting rid of the pile a crap and getting a new machine JMHO
GE Stacked washer dryer - Agitator Removal (Dryer Repair)
by Guest 5/31/2021 10:26:51 AM(UTC)
Kenmore 20022011 agitator removal (Washer Repair)
by d0ugparker 3/18/2015 8:46:07 AM(UTC)
kenmore agitator removal - bolt turns but won't come out (Washer Repair)
by kimkim 3/2/2015 9:25:47 AM(UTC)
Amana agitator removal (Washer Repair)
by Max Strasser 8/6/2014 11:09:33 AM(UTC)
Agitator Removal (Washer Repair)
by fourspots 5/3/2013 8:51:25 AM(UTC)
Older Maytag Washer Agitator Removal (Washer Repair)
by rjhornak 4/20/2012 10:40:17 AM(UTC)
Agitator removal (Washer Repair)
by kenziegranny 2/12/2012 7:36:24 AM(UTC)
by cutthroattrout1 1/4/2012 1:26:48 AM(UTC)
agitator removal steps; is washer lid removal required (Washer Repair)
by tomdrzich@hotmail.com 8/11/2011 5:36:48 AM(UTC)
by sabado 1/14/2011 6:22:25 PM(UTC)
by rpflynnsr 12/21/2010 11:13:40 AM(UTC)
by engcash 10/20/2010 11:01:54 AM(UTC)
Hotpoint agitator removal (Washer Repair)
by dleatherbu 10/10/2010 10:40:20 AM(UTC)
1980s whirlpool agitator removal (Washer Repair)
by billhuber 10/4/2010 5:20:06 PM(UTC)
by BARDOME' 9/6/2010 11:36:27 AM(UTC)
