JOYCENAPIER
#1 Posted : Tuesday, October 14, 2008 12:35:51 PM(UTC)
JOYCENAPIER
Will not heat.
replaced both fuses and heating element
Dryer work until moved to to location and changed the vent from the side to the back.
v2k04
#2 Posted : Tuesday, October 14, 2008 2:44:42 PM(UTC)
v2k04
If I am understanding you right you moved to a new house and dryer doesn't work? if this is true I would check the line voltage to the dryer You may have a problem with the house electrical and not the dryer
AJOHNSON
#3 Posted : Tuesday, October 14, 2008 10:16:56 PM(UTC)
AJOHNSON
I Had The Heater Element Replaced 2 Years Ago. So I Tried To Check The Heater Element And Took The Back Off The Dryer But Could Not See The Element. Where Is It Located?
v2k04
#4 Posted : Wednesday, October 15, 2008 3:25:44 AM(UTC)
v2k04
if its a maytag built Crosly and not a whillpool you release 2 clips and pop the top up, and its in the back dead center there is also a thermal fuse real small hard to see that always blows too
HELP! electric dryer will not heat (Dryer Repair)
by jaegray369 3/27/2012 6:31:52 PM(UTC)
Electric Dryer will not heat (Dryer Repair)
by dmerritt8712 3/26/2012 9:35:58 AM(UTC)
Whirlpool Electric Dryer will not heat (Dryer Repair)
by scramjet 8/21/2011 1:25:38 PM(UTC)
Electric Dryer will not heat up (Dryer Repair)
by varn99 6/2/2011 3:26:17 PM(UTC)
by sz9pm3 11/11/2010 3:32:53 PM(UTC)
Electric Dryer will not heat and timer does not count down (Dryer Repair)
by wes_cul 1/26/2010 5:08:31 PM(UTC)
by Eugene P 12/20/2009 10:49:57 AM(UTC)
Electric Dryer will not heat but runs fine! (Dryer Repair)
by dcrenlop 7/19/2009 1:51:32 PM(UTC)
by Shep 4/14/2009 10:37:42 AM(UTC)
