aaron2011
#1 Posted : Wednesday, March 16, 2011 4:47:59 PM(UTC)
aaron2011
Groups ready for retrieval: Registered
I am unable to remove the drum from the rear tub assembly.
The problem began with clunking and squealing sound. It also didn't seam to do the final spin cycle clothes came out wet. I found a broken shock absorber. Replaced that and the problem is still there. I began taring down washer, removing the tub assembly and am now stuck with the drum stuck in the rear outer tub assembly. How do I get the drum out from the rear outer tub assembly?
sidfink43
#2 Posted : Friday, March 18, 2011 1:05:25 PM(UTC)
sidfink43
You should not tear into it without a service manual, so here is a link to one from Frigidaire.
http://frigidaireservicetips.co..._TumbleActionWashers.pdf
Sounds like your bearings or spider support may have failed, in which case a new machine is probably the better option.
Maytag dryer drum removal (Dryer Repair)
by Tomjenks 11/14/2014 2:49:16 PM(UTC)
Drum removal (Dryer Repair)
by hollywood1962 3/11/2013 6:29:01 PM(UTC)
drum removal for whirlpool (Washer Repair)
by hnsberk 2/21/2013 12:56:53 PM(UTC)
Drum Removal Help (Washer Repair)
by HARRY HEN 10/20/2009 10:42:48 AM(UTC)
by HARRY HEN 10/20/2009 10:40:06 AM(UTC)
Washer drum removal (Washer Repair)
by ianos 10/11/2008 7:03:56 PM(UTC)
