The water line on my fridge was kinked and after I repaired it the ice maker will not get water .The water in door works fine and if I pour water into the ice maker manually it will make ice the one time I can hear the solenoid clicking trying to fill it but it won't fill up .thank you maddiesgramp
Originally Posted by: maddiesgramp  The water line on my fridge was kinked and after I repaired it the ice maker will not get water .The water in door works fine and if I pour water into the ice maker manually it will make ice the one time I can hear the solenoid clicking trying to fill it but it won't fill up .thank you maddiesgramp Valve is clogged with sediment. :)
Its also possible the inlet tube is frozen since it could have been weeping low pressure to icemaker, make sure its free of ice dam
First thank you for your answer. but where is the vavle and can i clean it or do i replace it thanks again maddiesgramp
The valve is connected to the water line. just follow it from the wall, 5-10 years is perfect timeline for a valve to fail, its not repairable. Very easy to replace
The valve is located in the bottom back right corner. You can purchase it right here from the parts department.
thank's i took a heat gun and warmed it all up and now it seem's like it is working fine.maddiesgramp
