fr8erdawg
#1 Posted : Sunday, October 12, 2008 9:15:44 AM(UTC)
fr8erdawg
wash machine spins really slow amd makes a sharp sound when it stops.
Drags1998
#2 Posted : Sunday, October 12, 2008 9:49:02 AM(UTC)
Drags1998
Check for a screw or nail going down thru the bottom of the wash tub, OR clothing stuck between the tubs!!!
fr8erdawg
#3 Posted : Sunday, October 12, 2008 10:07:58 AM(UTC)
fr8erdawg
Thanks for the reply. Found no hardware or clothing in tubs or between them. I think it may be a motor or clutch if it has one.
#4 Posted : Sunday, October 12, 2008 10:25:09 AM(UTC)
You have dragging brake shoes. Go to my article by putting in the search window "replacing direct drive brake shoes". This should be done before the motor burns up. If you have an amp probe a confirmation would be over 10 amps in spin with an empty basket.
Older Msytag top load washer main belt tension on model LA612 (Washer Repair)
by Guest 6/29/2024 10:22:44 AM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
GE Top load washer not draining (Washer Repair)
by Guest 6/25/2024 4:59:12 PM(UTC)
Washer won’t spin with load (Washer Repair)
by Guest 6/25/2024 5:32:07 AM(UTC)
Samsung Top Load Washer (Washer Repair)
by welchjames65@hotmail.com 6/21/2024 3:08:07 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
GE Profile Washer not draining and water not hot (Dishwasher Repair)
by Guest 6/8/2024 9:00:21 AM(UTC)
Kenmore washer 110.81821110 (Washer Repair)
by Hitzemup 6/5/2024 3:57:12 PM(UTC)
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Kenmore 70 series washer grinding (Washer Repair)
by Higginsdog 5/28/2024 4:17:38 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 5/21/2024 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
