RUUD Silohette II Furnace Tappan Condensor Unit- Model FS3BA-024KA (2 Ton)
Here is my current issue. Bought this home 18 months ago Newer furnace and condesor unit.
During the winter, Furnace can warm the house very quickly and efficently with a large amount of air moving thru the registers. During the summer months when we run the AC, it struggles to cool the house at all, with very little air flow from the registers.
I asked a buddy, he had me check to make sure the wiring had both Furnace and AC wires on the high speed for the blower and when i checked they were. Any suggestions on how to alliviate the problem with little air flow while using the condenser during our summer?
Brian
Need more info, ask, Im new to this forum, and not very versed in HVAC
The A/C should be wired for high speed, and the furnace should be wired low speed. If this does not help you need a fan control center. :)
So if the AC is currently wired on high, i take it i need a blower control?
You should have a fan relay on the unit mounted on top of the fan center. The low speed is red and high is black . Common is usually purple or white. I would venture to say the wires are reversed on that fan relay.A dang Ruud ain't that complicated.
Originally Posted by: SublimeMasterJW  You should have a fan relay on the unit mounted on top of the fan center. The low speed is red and high is black . Common is usually purple or white. I would venture to say the wires are reversed on that fan relay.A dang Ruud ain't that complicated. To you and I no, to a DIYer yes. :)
Originally Posted by: icehouse  To you and I no, to a DIYer yes. :) Yes to me, but wiring is no problem for me, ill look into it.
In my experience this problem is most likely the low voltage transformer located primarily in the furnace. when the transformer is shorted the fan relay will close on hgh speed and will provide heating when called for by the thermostat but will never provide the 24 volts necesary to change the furnaces motor speed or energize the contactor for the condensing unit, thus no cooling.
Question ? How can the fan relay energize if the transformer is shorted ?
